Where is the hybrid battery cooling fan intake?
Discussion in 'Prius v Main Forum' started by icyrius, Jun 10, 2017.
  1. icyrius
    icyrius Active Member
    233
    111
    Florida, USA
    2014 Prius v wagon
    My son's '11 Prius has an opening next to rear seat for hybrid battery ventilation. Where is the intake in the previous v? Is it the vent located under the driver's seat?
    Does it need to be kept without any blockages like my son's Prius? Does it need any cleaning?
    Thanks.
    49,500
    that should be the heat for rear passengers. no vents on the sides or bottom of the rear seat?
    yes, when you find it, don't block it. cleaning would be obvious, but the fan might, if you carry animals.
    check your o/m for location and warning.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    The vent is under the passenger side rear seat, you've got to get down and look up under the seat. That was one of the first things I looked for when I bought my v. It was odd not seeing a vent in sight like other hybrids.
    Raytheeagle likes this.
  4. Mendel Leisk
    38,729
    Just editorial: bold text should read "Prius v"? (n)
    (I know, rampant auto-correct.)
  5. icyrius
    233
    111
    Florida, USA
    2014 Prius v wagon
    Thanks. I will check it out!
  6. MazMaz
    MazMaz New Member
    Sydney
    2015 Prius v wagon
    i have 2015 prius v (7 seats) and i m checking everywhere for this but no luck. please help
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Oh! You have the Prius plus. It has the hybrid battery inside and underneath the center console between the two front seats. We don’t have the plus here in the USA so I’m not much of a help. I’d say just look really good around your front console
  8. Aaron Vitolins
    1,612
    1,144
    Franklin TN
  9. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Its under the right front seat. If it is RHD, its under the driver seat.
  10. Mollyisadog
    Mollyisadog New Member
    16
    Virginia, USA
    Where is it on the 2013? I looked but have not found it.
  11. bisco
    49,500
    should be on the passenger side of the rear seat back, by the safety belt
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
