Where is the Key Port for the Gen III 2010 prius?
Discussion in 'Gen 3 Prius Main Forum' started by MWIJerzy, Apr 26, 2010.
  1. MWIJerzy
    MWIJerzy New Member
    Appleton Wisconsin
    Can anyone please let me know where the Key port is for this prius IV. We have searched High and Low and can not seem to find where to put the fob if the fob battery would happen to not work or have a dead battery.
    Please advise.
    thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    There is no key port for the 2010. The directions are in the Owner's Manual on page 541 and copied below.
    Apply the brakes and touch the Toyota emblem side of the
    electronic key to the “POWER†switch.
    An alarm will sound to indicate that the start function cannot
    detect the electronic key that is touched to the “POWER†switch if
    any of the doors is opened and closed while the key is touched to
    the switch.
    To change “POWER†switch modes: Within 10 seconds of the
    buzzer sounding, release the brake pedal and press the
    “POWER†switch. Modes can be changed each time the
    switch is pressed. (​
    P. 162)
    To start the hybrid system: Press the “POWER†switch within
    10 seconds after the buzzer sounds, keeping the brake pedal
    depressed.
    In the event that the “POWER†switch still cannot be operated, contact your Toyota dealer.
    ITO52P165​
    STEP ​
    n
  3. theloop82
    theloop82 Member
    Spanaway, Wa
    Thats all true, once your inside the car, you can use the RFID in the smart key to start the car without any transmission from your smartkey, but the actual metal key that pops out is to unlock the drivers door to get you inside assuming your transmitter is dead, in which case you will need to use the above method to start the car.
