Where is the micro SD slot in my 2022 Prius prime LE (base model)
Discussion in 'Newbie Forum' started by Brandon King, Mar 4, 2022.
  1. Brandon King
    Brandon King New Member
    2022 Prius Prime
    My new Prius prime doesn't have any maps on it. Some web browsing suggests I try to make sure it has a map loaded into the microSD slot.
    I can't find the microSD slot to verify the card is in there right.
    Anyone know where to look for it?
  2. vvillovv
    vvillovv Senior Member
    3,747
    1,320
    NY
    It should be shown in the Navigation Systems Manual. The nav system has it's own manual.
    It looks like this on my 17 Prime Plus (base).
    warnin bright mornin sun showin every dust particle on the dash :cool: -4 ^ C
  3. Brandon King
    2022 Prius Prime
    Thanks. I'll have a look. The manual that comes with mine is for the 11.5 inch screen for some reason. Completely useless to me.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    This is NOT just another smart assed answer.............
    You need to find that information in your users manual so that it will, hopefully, be correct for YOUR specific model.
    Or ask your dealer with the car present.
    Well meaning owners with all kinds of different models will likely give you answers that are WRONG for your specific car.
    If it actually has the NAV feature, I would certainly think it would come with the chip installed.
  5. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    If your car is a 2022 Prius Prime LE as stated, then you DO NOT have an in-car nav system, thus there is no map data in the head unit. Your car is equipped with Apple Car Play and Android Auto. Use your phone connected to the head unit via USB wire to use the phone's nav system. On the 2020 LE mode, the car came with the Scout GPS app that also required a phone app and wire connection, but IIRC, that app is no longer on the newer LE models.
    EDIT: Oh, I just realized you are in Canada. I am not sure if the base model of Canadian PP is the same as the US version of PP LE. My info above is for the US version PP LE.
    OP's car is a 2022 model. Toyota stopped in-car nav on the base (LE) model starting 2020, IIRC. My 2020 LE came with Scout GPS phone-based nav, but no in-car nav system.
    #5 Salamander_King, Mar 5, 2022
    vvillovv likes this.
  6. vvillovv
    3,747
    1,320
    NY
    I found the manual hard to follow in the beginning too, until I learned more about what the 2017 Prime Plus actually had for options and what it didn't have. The manual I have includes all the options available for all 3 2017 trims, Plus, Premium and Advanced. It was confusing at best.
    Salamander_King likes this.
