Where is the search field, looking traction battery changes G3
Discussion in 'PriusChat Website Questions' started by chronart, Mar 24, 2014.
  1. chronart
    chronart Junior Member
    Have a 2001 and a 2010. The traction battery has failed in the 2001 and my wife says no to a rebuild and I say no to a dealer's new battery price, so looking for a newer used replacement Prius, to kill time until gen4 comes out. When I go on Craig's List I am surprised at the number of 2005,6 that say they have new batteries in them. Seems like gen2 has a higher failure rate than gen1. Figure it's just a statical fluke on the latest listings on Craig, but thought I'd better do some checking. Did gen2 make the batteries run hotter on average. I thought gen 2 batteries had lower source impedance so probably ended up cooler but I don't know how the average currents compared.
    What were the changes between gen2 and 3? Sorry to bug the forum but I can't seem to find the search box for this forum. Thank you.
    Barry Gamble
  2. neez
    neez Member
    194
    37
    Statistically speaking, the gen2's sold a boatload more priuses than the gen1. The gen2 was when the prius really took to adoption. So yes, you will see more that need batteries based soley on that reason alone, even if it has a lower failure rate, it's still a rate. So a rate on a much higher volume of cars will net you more hits in your search. Here's a chart below for example:
  3. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Just use Google search in your browser with Priuschat.com as one of the search parameters. Works much better than the site's search function.
    SCH-I535
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Put this in the search box of google:
    Code:
    site: priuschat.com whatever you're looking for
  5. chronart
  6. chronart
    Now I see the problem. I was on an iPad and the search box was not showing up.
    Thank you, Barry
