Where to buy ATF?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by almypal26, Jan 5, 2013.
  1. almypal26
    almypal26 Member
    101
    So Cal
    Where is the best place to purchase ATF fluid? I'm guessing online, but through which website? I looked on Amazon and Ebay, there were some for about $29.00 a bottle. Is that expensive? Can I get it cheaper? (I would hope so). What is the part number? And how many gasket(s) do I need to replace when I have this service done? I've read I would need four bottles (quarts). Is there anything else I need? I'm going to have my mechanic do the service. Thanks in advance for your input.:confused:
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    The last time I exchanged ATF it cost some $8 - 10 a quart at the dealership.
    BTW, if you an change engine oil, you can change ATF.
  3. TsKarma
    TsKarma Junior Member
    82
    You will need to get 4 quart. Different dealership has different pricing, so do check their website or call for coupons and/pricing. Check the forum for tips and instruction if you want try it yourself. The car needs to be leveled. The best price I was able to get was about $45 if I brought 4 ATF. Nothing else needed.
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
    4 bottles WS-ATF and two gaskets for the two plugs.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Yes but takes 3x longer the first time
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The only ATF fluid that u can use has to come from the dealer.....no where else. If u put anything other than the Toyota WS ATF, expect ur CVT transaxle to live a short life.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Like others, I only get my ATF fluid along with the washers from my dealer.
  8. Mendel Leisk
    38,726
    There's a few adventurous souls who defend (to the death, LOL) their right to put alternate fluids in. And the may be ok.
    But really: why bother, why chance it, why jeapordize your warranty? The kosher Toyota ATF WS fluid is cheap and readily availabe from the dealership. Same thing for the fill/drain plug washers.
    It's not that complicated, just follow the correct procedure.
    Rebound likes this.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    4 qt from the dealer, price is about $11/qt (though I paid $9) and $2/ea for the washers.
    You will need either a gear oil pump (tedious) or 3' of 1/2" OD tube plus a measuring funnel ($5 at Walmart or O'Reilly) to refill. Refill should be about 3.7-3.8 qt.
  10. almypal26
    almypal26 Member
    101
    So Cal
    Thanks (everyone) for the info. I know most PC members suggest changing the trans fluid at about 30K miles. Just wondering anyone changing the fluid at higher mileage, 40K or more. I have 72K miles and sad to say I've put it off for way to long. This will be the transaxle fluid change.:eek:
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    There are over 3 million Toyota hybrids running around, so odds are pretty good at least *one* other person has delayed the first ATF exchange past 30k miles.
    Feel better now ? ;)
  12. almypal26
    almypal26 Member
    101
    So Cal
    Thanks SageBrush. A little better, now I can sleeep better.:sleep:
  13. Bill Norton
    Bill Norton Senior Member
    1,844
    603
    MONW, Ks.
    Yet some follow the Toyota recommendation of never changing it.
    This is an technical look at what happens if you wait until 112K miles to change.
    ATF fluid changes ARE Required. | PriusChat
    Keep in mind, probably the vast majority of Priuses on the road may never get this essential service.
    Good for you about doing this service to your car!
    And I'm one of the owners that says "Horse Feathers" about Toyota's house brand of ATF WS as the one and only ATF that can be used.
    Walmart has their low dollar ATF that states it is compliant with ATF WS, and many other also make this claim.
    It's not a mysterious automatic transmission. It's not a CVT with the variable belt.
    It's a gearbox that needs a clean lube in it.
    I use High-Quality American-made Synthetic Lubricants.
    mtbiker53 likes this.
  14. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    The last time I bought ATF-WS was 2 years ago. List price was $8/qt from my local dealer, I got it for $7.20 because I bought the car there.
    TsKarma likes this.
  15. TsKarma
    82
    I had mine done at 81k to be on the safer side (it helped my decision when my local mechanic only charges $50 when we bring our own trans fluid). I am assuming that the previous owner didn't change it...
    My Toyota ATF was about the same price if not slightly cheaper than what Tumbleweed quoted above (I had a 15% off coupon for parts, etc), so 4 quarts cost about $30. All in all, $80 for a piece of mind.
  16. wetback1
    wetback1 Junior Member
    Courtenay, B.C. Canada
    My 2010 Prius has just hit 80000 KM (50000 miles) and after doing some reading here I thought I'd change the transmission fluid. I bought 4 'litres' (946ml) of WS ATF and 2 gaskets from my Toyota dealer for $39.69 taxes included. The fluid is labelled made in Canada which I thought was interesting. The factory gaskets were solid aluminum; the replacements look like spark plug gaskets, more crush to them.
    I bought an outboard gear oil pump from Princess Auto for $9.99 and it worked great, although it takes 125 'strokes' to empty a litre bottle. The refill took 3.5 litres. The whole job took less than 2 hrs from start to finish.
    Although the used fluid was definitely darker than new WS, I've seen a lot worse through many years of tranny fluid changes. Bear in mind that your engine oil doesn't come out the way it went in either; this just shows it's doing it's job. So although it may be useful preventative maintenance I wouldn't worry about your transaxle falling apart if you don't do it every 30K :) FWIW I just changed my first cabin air filter and am still using the factory engine air filter - and it doesn't really need changing yet. oilpump.jpg transdrain.jpg
    spiderman likes this.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    From the last photo, the fluid doesn't look all that bad (still translucent) compare to like F8L's and others at much less. Makes we wonder if something is wrong is some of these trans-axles?
  18. Bill Norton
    1,844
    603
    MONW, Ks.
    That pump sounds like a lot of work compared to a simple funnel and hose setup where you stand up and pour the bottles into the funnel positioned above the right side of the engine. If you take out any screen in the funnel, it's even faster.
  19. wetback1
    My primary concern was not getting it all over the place. If I had a 'good woman' :) to do the pouring while I held the hose and checked the level the funnel probably would have won out; alas I live alone...
    I did follow someone else's advice and use a white zap strap as a dipstick, works great!
  20. Bill Norton
    1,844
    603
    MONW, Ks.
    I don't follow you. The funnel just sit there on the right side of the engine ( car right ) and the hose goes in the fill hole. You pour it in the funnel until it pours out the fill hole, have the drain pan there, wait for the excess to stop, pull the funnel and hose out from the top and Bob's your Uncle. Very little on your back-under the car time.
    I probably spend more time getting the car level on jack stands than the actual ATF change. I work through the oil change door. I can get my oil analysis bottle in there too. It drains onto the belly pan a little bit but that can be cleaned up with a few paper towels and a small blast of brake kleen.
    My next change is due. Maybe I'll track the time and take some pics and post it as a "Quick ATF Change" thread, you think?
