Where to find a power source behind the radio?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Manny Khan, Jun 2, 2018.
  1. Manny Khan
    Manny Khan New Member
    Orange County
    Hi Guys,
    I am planning on adding a android mirroring box behind the navigation unit so I can mirror my phone. But the mirroring box has a positive and negative lead that needs to connected to a power source. Where is everyone getting this source or using to tap in?
    Thank you in advance.
  2. Manny Khan
    Orange County
    52,838
    can you run it down to the power outlet below the flying bridge?
    ITBland likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    In that situation, I would run a piggy back double fuse from the fusebox with power cable going behind to navigation unit so the device is fused and fused is assess-able.
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    +1 on tapping a circuit in the fuse panel under the driver's side dashboard.
  6. creatorcake
    creatorcake Junior Member
    37
    16
    41.1952133,-73.288405
    Hi im pretty new here and was only able to write at all by responding to this post. My main question is can a low 12 volt battery trigger the replace hybrid battery code? My 2014 prius threw the code a few weeks ago so I used my obd 2 reader to shut the code off everything is now working normally although the obd 2 reader says the battery code is permanent.
