Where to get techstream? Can anybody refer me to a good vender on ebay that worked for them?
Discussion in 'Gen 2 Prius Main Forum' started by justlee, Oct 4, 2019.
  1. justlee
    justlee Junior Member
    23
    CA
    Where to get techstream ? Has anybody got a usable setup from ebay and could point me to a good vendor or at least ones to avoid? Toyota price is not doable for me but I would like to be able to fix anything on the car or at least know exactly how it works. I want to get some sort of diagnostic tool that gives me more info than my Harbor Fraught scan tool that can't deal with some of the Prius systems. Is the Torque app an adequate substitute for techstream?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Amazon.com:
    Min Vci
    or Vx Diag
    Both run on laptop both have knockoff Techstream that work fine.
  3. meeder
    meeder Active Member
    239
    161
    Doesburg, The Netherlands
    Do you need the complete set with techstream and the adapter or will a good quality OBD-II adapter work as well?
    I own a ELS27 adapter which supports more advanced features like the MS-CAN bus which normal ELM327 adapters do not.
  4. lexidium
    lexidium Active Member
    236
    110
    manchester
    You buy the cable and you get the disc with it
  5. lexidium
    236
    110
    manchester
    I bought mini vci from Dragon-diagnostics on Ebay. It comes with a disk containing drivers and version 10 of Techstream.
    I installed it on a windows XP 32 bit laptop and it works great. I programmed two keys with it (non smart keys)
    It's difficult to install on 64 bit windows 7 machine but very easy on 32 bit XP.
    Here's the link: dragon-diagnostics-uk on eBay
    Cheers
    edthefox5 and bisco like this.
  6. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Yes. Its very common. The VCI is cheap. Buy sometimes cranky to set up. The Vxdiag is much easier to set up on a laptop. I have both. Both work great. I use a burner Dell 630 XP machine I have had for 100 years as I do not expose this software to my good pc's or laptops. But has full techstream.
