Where to install Catalytic Converter Theft Prevention in San Jose, CA?
Discussion in 'Gen 2 Prius Main Forum' started by Doralynn, Sep 11, 2020.
  1. Doralynn
    Doralynn Junior Member
    San Jose, CA
    I've been hearing a lot about catalytic converters being stolen in under 5 minutes. I live in San Jose and I do have a garage to park my Prius - but have concerns when running errands. So, I've decided to take preemptive action by having a shield installed (and possibly other redundant theft prevention - if possible).
    I'm looking for a muffler (or general body shop) that can facilitate a full service installation in (or near) San Jose, CA
    Thanks in advance!
    Doralynn
    Isaac Zachary likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,056
    4,500
    Pacific Northwest, USA
    It's a very easy install... If I were you I'd find a small time neighborhood mechanic with a lift... They can do it real quick... You could probably also do this yourself with a jack and some jackstands and won't take more than a couple-few hours, but depends on your tools & skills.
    #2 PriusCamper, Sep 11, 2020
  3. Moses Bruh
    Moses Bruh Member
    97
    29
    around 170-200 for the cat shield, mechanics would prob charge 50-100 bucks to install it depending if they actually use the rivets and bolts provided by the cat shield. If they just use sheet metal screws it will be cheaper, expect it to be closer to 100$ if the mechanics follow the install properly. For me since i did not want rivets on there, i used 3 different types of screws (Philips, hex, and security torx head) to secure the shield so the only easy way to remove it would be to grind and cut off the entire shield, which in that point there isn't anything you can do.
  4. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    Moses write, "3 different types of screws (Philips, hex, and security torx head) to secure the shield "
    I think that is an excellent idea.... may slow down the thief and even slower to remove than rivets.
    FWIW...Hey all our co-members, I think labor rates in San Jose Calif are near $175.00 an hour.
    OP... Sadly, I have no recommends on a muffler shop or independent mechanic in your area.
    Good luck...seems like an easy install job.
  5. Doralynn
    San Jose, CA
    Thanks for the tips. This is very helpful. By the way, what is the typical cost of replacing a catalytic converter on a 2007 Prius? Is this something that can only be done at the dealership?
  6. bisco
    49,380
    $2,000. if i recall correctly. anyone can do it, but cali only smogs oem cats. check in with caroline at luscious garage
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    @Joele3 lives down your way and may know someone:whistle:.
    He has a smog shop too, so a good member to know(y).
    DJ92 likes this.
  8. Xterra72
    Xterra72 Senior Member
    1,397
    1,654
    B&C Auto in San Jose close to 87.
    almost got it but had to think about it because of my Cusco brace.
    Hope it all works out
    Raytheeagle likes this.
  9. hill
    8,158
    it's a bit pricey . . . . but this will not only protect your cat - it'll cover the whole enchilada
    t_newt, Doralynn and Raytheeagle like this.
  10. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    I bet those that opt for this option don't leave their car in accessory mode very often ;).
    Otherwise they're repacking the 12 volt often:rolleyes:.
  11. Doralynn
    San Jose, CA
    How would a smog shop know if I had an OEM catalytic converter or not? Are they checking some type of identifying numbers located on the cat or something?
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,153
    2,204
    Taylors, SC
  13. bisco
    49,380
    yes, they check everything in cali...
  14. Doralynn
    San Jose, CA
    So, if I add a plate to prevent theft of my catalytic converter then will this cause a problem when I get my car smogged? That is, will the mechanic have to remove that plate to check numbers or visually inspect and observe I have the the proper cat installed?
  15. bisco
    49,380
    no, they already have it figured out
  16. The Lizard King
    No. There are holes in the plate strategically placed so that the smog inspector can see the OEM Toyota stamp and part number.
  17. Moses Bruh
    Moses Bruh Member
    97
    29
    Yea, and San Francisco Toyota dealer installs the same cat plate sold by cat security or w.e the name was. Although honestly toyota should offer to cover the plate and install for free for the gen 2s
  18. t_newt
    t_newt Active Member
    217
    246
    I like this. I had to track down the video:
    They have a whole crazy website at tesladownunder
  19. wasambi
    wasambi New Member
    San Jose
    If you're looking for an installer for catshields, you can take a look at MillerCAT's website. They seem to have San Jose covered so you should have plenty of choices.
  20. DJ92
    DJ92 New Member
    Santa Clara
    How much did it cost for the shield installation bdw?
