Where to mount your GPS in 2011 Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MacArthur, Dec 4, 2011.
  1. MacArthur
    MacArthur Junior Member
    23
    Great Falls, VA
    newbie here. Just got my 2011 Prius for 2 weeks. Love it, except couldn't figure out how to mount my Garmin GPS.
    I did go through all the previous posts of similar topic, but couldn't find a satisfactory answer. Here are the reasons:
    1) I want to mount my GPS HIGH, so that no need to move my sight away from road too much. I can't go with those "Cup-Holder Mount" or the ProClip mount aside the cup holder, which are way too low for me. Whenever you bend your head down to look at GPS, you are prone to accident.
    2) Preferably mount on top of the dash, somewhere next to the MID. Used to have a Vent Mount. But the problem with 2011 Prius is that, the vent grill is too thick, and too deep. The old vent mount works great on my previous car just won't click on the 2011 Prius.
    3) With the Gen III redesign, the dashboard layout is totally different to Gen II. I appreciate all of those who post their pictures of GPS mount solution, that should have been very helpful, unfortunately won't apply to Gen III dash. I just want to know how to mount it in a Gen III Prius.
    Any advice is appreciated. Thanks!
  2. MacArthur
    23
    Great Falls, VA
    I've also tried with the suction cup mount, to fix it at the bottom of the windshield. Because of the aero-dynamic design of the contour of wind shield, it's so far away that I might need a binocular to see the GPS...
    So suction cup mount is no use too... I guess...
  3. zyx345
    zyx345 Junior Member
    42
    Northern, NJ
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I have heard of others suction cup mounting it to the small window between the drivers door and the windshield. Don't know if that would work for you?
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I have my Ultraguage fixed to that side window with a flexible stalk. Works well.
    I have a Navman for which i modified the mount using a strip of stainless steel and glued it to the dash with black gasket silicon sealer. The sealer rubs off easily when I need to move it.
  6. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    We got tired of having to stick the suction cup to the windshield on the other vehicles, only to have it constantly fall off. We got one of the bean bag style mounts (at Target) that just sits on the dash. We keep it sitting on the far left side of the dash. Easy to read and no where near the Prius gauges.
  7. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    My recommendation is to go with proclip, if you are not doing a HU with GPS integrated.
    This is how I had mine mounted on the A/C vent with proclip. It is a great spot.
    There is another proclip mount that goes directly above the A/C vent, this one would not obstruct the air flow.
    Before proclip, I used to have that friction mount mentioned before, you can place it right above the dash behind the steering wheel (probably the best place), but the biggest down side is that is moves. Between the road bumpiness, the weight of the power cable and one touching it to select streets or view has that thing dancing all over the dash. Save yourself the $30 of the friction mount or the super obstructing suction cups and go proclip.
    Cheers!
  8. MacArthur
    23
    Great Falls, VA
    Thanks SwaggingPrius -- this is what I'm worrying about the Friction Mount, that it might move around.
    Suction cup to that tiny window? That's an interesting idea. I might give it a try and see how it look.
    So far looks like the ProClip Center Mount (Item #: 854354) would be the best solution. SwaggingPrius, is this the one you are using right now?
    Thanks to all of you who replied and shared ideas!
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Probably depends on what make and model of GPS unit you have, but Magellan has an adjustable arm with a suction cup that fits in the small window to the left of the driver-side dash. It's a little awkward getting it set up and adjusted the first time but it works well. RadioShack sells a beanbag type as well.
  10. alfa737
    alfa737 Member
    126
    27
    Hi there,
    here is what i use for the gps and phone. the vent are bigger than other cars so i had to remove the sliding clip and then it fit fine.I can swap between the two. I find myself using the phone to navigate more often because i can have the phone on the internet and get live traffic maps from google maps.
  11. fulltank
    fulltank New Member
    230
    38
    Arkansas
    I've always used the window suction cup and never had any problems. Don't use the Garmin that much so would never want to permanently mount. Besides being an eyesore it's just welcoming theft.
  12. swaggingprius
    88
    29
    East Coast
    Yes, that is the one on the picture, or #213470. This one does not block the vents.
    They are both solid and will not move.
  13. El Dobro
    El Dobro A Member
    6,978
    3,213
    I use the Garmin beanbag and it doesn't move around at all. When I pull in at a stop, I pick it off the dash and put it under the seat, so there's no signs of a GPS anywhere.
  14. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I have 2 of these that I use in my other cars. All of my cars have a Dashmat & it doesn't move around at all. I don't need it in my Prius since mine came with Nav already. That is also another option, you could get a Rosen nav in dash HU. I like it a lot more than the OEM nav in my Prius.
  15. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    This is an old pic that post everytime a new thread starts asking were to mount your GPS. I have it in the same location but I hind the wires.
  16. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    Here's where I keep my Garmin GPS:
  17. MacArthur
    23
    Great Falls, VA
    Thanks but guess I'll need lots of time to get used to looking down for direction then looking up for road... Only if I'm driving a helicopter... :D
  18. MacArthur
    23
    Great Falls, VA
    Interesting... is this an aftermarket GPS? Is it something I can DIY? Or it's a project in workshop?
  19. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The nuvi 2455/beanbag combo is more stable on the dash but it still slides around so I can't corner like I can without it.
  20. Rebound
    3,964
    2,612
    Portland, OR
