Where to put EZPass on Windshield for 2022 Prius Limited?
Discussion in 'Gen 4 Prius Main Forum' started by dfine1966, Feb 21, 2022.
  1. dfine1966
    dfine1966 Junior Member
    77
    2022 Prius
    I have a 2022 Toyota Prius Limited. I'm having problems on where to place my EZPass rectangle transponder due to where the camera's are on the passenger side. I don't want to put it on the driver side for it would be in line of site. I've been told I should either put it under the big black covering under the mirror or on the passenger side an inch under the black dots. On the passenger side there are multiple camera's and other sensors below the smaller black covering to the right of the the bigger black covering. Anyone else having this problem or have it installed it. Please, any help would be appreciated . I even call the dealership, but they were unsure where to put. I included pictures of the driver side and passenger side.
  2. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I just mounted my EZpass centered below the mirror. It is small and doesn't interfere with vision.
    JeffD
    dfine1966 likes this.
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    The transponder is strong enough that you can safely keep it in the glove box and still works. It does not have to be on the windshield at all. But if you want it mounted, you can place it right on the black plastic behind the rearview mirror as shown below. You can't see it driving and no one can see it from outside front of the car either. I never had any problem.
    daisy555 likes this.
  4. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Another one for under the mirror and on the glass. I cannot see it with the big mirror.
    Pulse07 and dfine1966 like this.
  5. dfine1966
    77
    2022 Prius
    I decided to put it under the mirror. It looks like it should work. Thanks
    iPhone ?
  6. Media_Tech
    Media_Tech Junior Member
    inside the Beltway
    Is there a problem with mounting the transponder on the black dots? (Metallic, perhaps, and thus RF shielding?) Mine has been approx. one inch to the passenger side of the camera housing and approx. one inch below the roof for two years, and AFIK it has never failed to be read.
  7. Salamander_King
    10,975
    8,873
    New England
    You won't have a problem with the transponder, but you may encounter a problem with the car's camera system as per the owner's manual.
  8. jdenenberg
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Attaching something on the inner surface is not going to interfere with the video system.
    JeffD
    Pulse07 and Salamander_King like this.
