where to put phone?
Discussion in 'Prius c Accessories and Modifications' started by ElectroLund, Dec 5, 2024.
  1. ElectroLund
    ElectroLund New Member
    Colorado Springs
    2014 Prius c
    I'm not so much looking for a phone mount of which there are so many. I don't want my smartphone to take over my driving experience.
    Just looking for the occasional mapping that I need to place it somewhere so I can glance at directions.
    There's that funny angled slot right in front of the steering wheel that is temping, but it angles the wrong way. Anyone use that somehow?
  2. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    We took advantage of the fact that the Prius c uses a nearly universal mount for its head unit, so we put in one that could do CarPlay/Android Auto. So now the phone usually sits in the tray over the glovebox, and the map comes up on the stereo display.
    I did notice that there's a perfect slot for the phone* right next to the parking brake handle. Can't see the screen, but it's ideal for connected charging & CarPlay use.
    You might get somewhere with one of the cupholder style mounts available today.
    *for older, smaller smartphones, anyway.... pretty much nothing made since 2015 can fit in there.
  3. Peter Danlyn
    Peter Danlyn Junior Member
  4. Jumpedinthepriasus
    Jumpedinthepriasus Junior Member
    46
    Ct
    Use a Suction cup mounted phone holder arm (the extendable ones are better) and mount on the left side to the little window on the front of the door; It may block your Left A/C vent alittle bit and placement of the charging wire can be annoying but thats the only location ive found to be unintrucive;
    Careful when opening your door; Align it so it doesnt hit the dash when opening and closing
  5. JimLudden
    JimLudden Member
    89
    36
    Taos, NM
    2024 Prius Prime
    I keep my iPhone in my pocket. CarPlay works just fine that way. On longer trips I need to keep the phone battery up, so put it in the console and connect to the USB port.
