Where to split into gas system
Discussion in 'Prime Accessories and Modifications' started by Mikhail Bond, Nov 16, 2020.
  1. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I just added a hitch mounted 10 gallon tank..
    Anybody have some ideas where I can tie into the gas lines to feed into the main tank.
    Because of remote work we have been driving extensively around the US and I’d like to reduce my gas stops.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    YIKES.
    No,NO, BAD idea to try and permanently tie that into the main system.
    If the main fuel pump is IN the gas tank, there is no good way to do that.
    You drain the gas OUT of the aux. tank into a can and the POUR it into the main tank.
    BUT.....unless you have a heavily reinforced tank made specifically for external fuel use.......your setup is DANGEROUS and probably illegal in most places. One rear end collision and......instant cremation.
    pghyndman likes this.
  3. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    What if it’s a feed into the fuel port? Gravity fed.
    how is this any different than a jerry can mounted on the back of a jeep or a tank mounted on the rear end frame of a truck.
    I get what your saying and from a risk perspective this is a stupid idea and I will 99% not do this.
    But I like the thought of 1000 mile range
  4. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    The gas tank is pressurized...
  5. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Just curious... remote enough to not have a chance to stop at a gas station in 500+ miles?
  6. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    No I just don’t like stopping for gas.
  7. Salamander_King
    10,975
    8,868
    New England
    Yeah, but where do you get the 10 gal gas in your jerry can?:confused:
  8. bisco
    49,494
    trade in for something with more range? is there such a thing?
    i don't see why cutting a tee into the fuel line under the rear seat would be a problem...
  9. Mendel Leisk
    38,728
    Is this even legal?
  10. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    If the added tank is not designed to be sealed & pressurized, there could be gasoline showers...
  11. bisco
    49,494
    of course, you'd need a one way diverter valve
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    What exactly is this "fuel port" you talk about ?
    Even the gas tank and filler neck are slightly pressurized on most modern cars, so there is no "gravity feed" anywhere.
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    No, likely NOT in most places.
    OFFROAD is another story.
  14. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    From the delivery guy ;)
    Oh the world we live in. Gas delivered at the expense of others...
  15. bisco
    49,494
    we need on road fueling, like those airplanes
  16. Prodigyplace
    11,696
    11,318
    Central Virginia
    You mean refueling while still driving? Planes can be refueled in flight.
  17. sam spade 2
    7,035
    2,788
    2017 Prius c
    Technically only military planes.......and a scant few others specifically designed for that.
    Switching tanks in flight isn't quite the same as "refueling". :)
  18. bisco
    49,494
    exactly
    Prodigyplace likes this.
  19. Prodigyplace
    11,696
    11,318
    Central Virginia
    Actually you want your flying car.
  20. bisco
    49,494
    with unobtainium power requiring no refueling!(y)
