Where to tap a wire under the hood?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusII&C, Oct 17, 2021.
  1. PriusII&C
    PriusII&C Active Member
    429
    145
    San Jose, California
    To deter the catalytic converter thieves, I plan to install an alarm under the hood for motion sensors. Where under the hood can I tap the wires to the 12V auxiliary battery power so that the power to the alarm is not interrupted even when the car is turned off?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,500
    Taylors, SC
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  4. PriusII&C
    429
    145
  5. ChapmanF
    18,552
    As was pointed out in that other thread, those two locations are unfused, so whatever circuit you push on there had better have a fuse of its own.
  6. PriusII&C
    429
    145
    Understood. Thx.
  7. Mendel Leisk
    41,908
    Here's how to access the main incoming 12 volt point, on the under-hood fuse box. It's a ring style connector. Any yeah, good to have an inline fuse, on whatever you add:
  8. PriusII&C
    429
    145
