Where's the Outdoor Temperature Sensor
Discussion in 'Gen 3 Prius Technical Discussion' started by Rebound, May 20, 2012.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I have a 2012 PiP. After washing her yesterday, the climate control indicated an outdoor temperature of 64. It was much hotter. Some water must have been in the sensor. Where's it located?
    Thanks!!
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    on the 2010 is just behind the lower grill opening towards the driver's side.
  3. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Thanks, was wondering that myself.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Actually I was working around it when I put the mesh behind the grills. It's at the lower centre of the front of the car, about 3" in front of the A/C rad. You can see the cable running down there from the top. Well, you can if you remove the top piece of plastic. ;)
    Rebound likes this.
