Which 12v battery should I buy?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DonVentura, Mar 20, 2013.
  1. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
    I've searched and can't find any of the posts I read last year about 12v battery options.
    Besides Optimal, Exide AGM & Toyota battery I remember some options some folks are using a mobility battery. Can anyone direct me to those posts or give me your opinion please. I need a new battery ASAP. Thanks
    49,429
    i would go with optima, just make sure it's charged before installing.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    In the US, you will not find other AGM batteries with external venting and JIS posts in the correct size and orientation.
  4. DonVentura
    78
    Ventura, CA
    Thanks for the replies, looks like I'm getting an Optima.
  5. hlunde
    hlunde Member
    419
    74
    Ideally you would buy a larger one! I expect that one will become available at some point.
  6. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    You might find this thread helpful. http://priuschat.com/threads/fitting-mobility-12volt-agm-battery.122920/
