Which AC setting do you think is best?
Discussion in 'Gen 2 Prius Fuel Economy' started by natural_tools, Jul 25, 2005.
  1. natural_tools
    natural_tools New Member
    32
    Dallas, TX
    Living in Dallas, there is no way to avoid using the air conditioner in the summer. So while I'm sweating in my black hybrid oven, I'm wondering...
    which AC setting is the best for MPG: low temp with low fan or higher temp with higher fan?
    A lower temp would require more condenser which seems like it would require more energy.
    A higher fan would obviously require more energy to spin the fans faster.
    So which way is easier on the engine and gets me MPG numbers at least a little closer to the outside temperature number?
    Any guesses?
  2. prius04
    prius04 New Member
    1,161
    NorthEast USA
    The condenser works by compressing the refrigerant. When that refrigerant later expands, it causes significant cooling. But it needs the fan also to move that cool air into the passenger compartment.
    The fan alone works simply by moving air around.
    Thus, the fan must use less energy, even if the fan is at maximum and the condenser at low. Compression takes a lot more work than just moving air around.
    The AC will cool the car even if you are not in it. A fan will not lower the temperature in the car at all. It relys on the principle that moving air causes water to evaporate off your skin quicker than still air would. And that water pulls heat away as it evaporates. This is why a fan causes you to cool off some.
    Thus, a fan is useless without a human with the ability to evaporate water off the skin. So don't leave your fans on when you go off to work. The electric motor actually adds heat to your house, and moving air does nothing for your couch.
  3. Robert Taylor
    Robert Taylor New Member
    451
    Rocket City
    Get the Huper Optik nano ceramic film installed for all windows but the front glass at a 35 rating. This will actually help reduce the heat load significantly.
    I should have done it, but failed due to a snafu at the closest dealer, 100 miles away.
  4. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
  5. Anonymous
    Anonymous Guest
    I concur with flareak. I have it set at 76 and my mileage pretty much doesn't suffer because of it, relatively speaking of course.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I use Auto A/C usually set to 79 degrees. I get no complaints from a spouse that will complain if she's not comfortable. The kids seem to sweat a little in the back seat but without complaint and not badly.
    I've been experimenting more with using 80 degrees on auto AC with the passenger side vents shut off when I'm driving alone and that seems pretty comfortable too. I doubt it makes a huge difference in mpg, but I'll take any fraction of a percentage on the 100+ degree days we've had the past week. I had a real struggle keeping my mileage up to my standard during the past week due to heat and AC use.
    Note that in Auto setting when the car is hot the compressor and fan run hard to cool the cabin down, then automatically adjust both compressor work and fan speed to maintain the temp while minimizing the power drain. I think most people think it's effective in doing that though others have said the fan speed is too low and that back seat passengers tend to be too hot.
  7. Anonymous
    Anonymous Guest
    79 in Missouri in the summer? Gaaaaah, I'm glad I'm not in that backseat.
  8. shocker
    shocker Junior Member
    89
    Northeast
    I have the auto set for 76 as well and I haved been getting great mileage in heat.
  9. prius04
    prius04 New Member
    1,161
    NorthEast USA
    I think one of the keys to being comfortable with a highish AC setting is to have the blower aimed at your upper chest. This is the point that Evan made and I wanted to reinforce it. And if there is no passenger, then to turn off the vents on that side. Thus, with the outside temp at 90, you might be just fine with an AC setting at 80.
    And if it's super hot out, aim at least one of the vents at your face.
    However, if there are people in the back seat, there is no way to aim it into peoples faces. To make it comfortable for them I think you need to have the setting a bit lower.
    But the higher the setting that you can tolerate, the better will be your energy use.
    And since I was about 40 before I had my first car with a working AC, I have no problem with kids in the back seat enduring a higher setting. But not my in-laws.
  10. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    In my very low humidity southwestern climate, high speed fan works great with cabin set at 77 - 82 -- depending whether passengers are in the back of the car.
    If I could aerate my back, I'd be even happier. Perhaps beads would help ?
  11. jamarimutt
    jamarimutt New Member
    985
    I use 74 and auto.
  12. Anonymous
    Anonymous Guest
    That doesn't actually work for me, Prius04. Initially, I like the driver side vents pointed at my face but after that, I point them up and away. I also keep all of the vents open, pointed in various directions because I like the entire cabin to be cool. It seems to me that the people in the back would be comfortable too, thataway.
  13. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(prius04\";p=\"110506)</div>
    I find that doesn't really work if it's sort of humid and about 80 degress outside. The A/C doesn't turn on and you end up with 80 degree humid air blown at you which gives me a clammy feeling. At which point, I have turn the A/C on to reduce the humidity, and then cool the cabin, since it would be too cold to have it blast in my face at the temperature setting required for the A/C to kick in.
  14. prius04
    prius04 New Member
    1,161
    NorthEast USA
    <div class='quotetop'>QUOTE(kaysea\";p=\"110566)</div>
    Yes, but I thought this thread was heading towards what to set the AC to and at the same time save the most on MPG.
    Cooling the entire cabin will have a bigger hit on the MPG than just concentrating the cooling on the driver alone. Seems to me that if you aim the air at your face or trunk, you can have the AC number set higher. Thus, be reasonably cool and at the same time optimize MPG. Actually, if comfort were the issue alone, I too would cool the entire cabin.
    This is where I was coming from.
  15. natural_tools
    32
    Dallas, TX
    I've always assumed that by keeping all the vents open, it then cools the entire cabin, which makes it feel cooler. If it's a comfortable 79 blowing in my face, but a muggy 95 circulating back around me, then it's not effective.
    Also, if the controls are set to recirculate, does it matter how many vents are on?
  16. Anonymous
    Anonymous Guest
    Yes, Prius04, but the way I do it, the MPG doesn't go down and even goes up a bit. Using recirculation part of the time helps. But isn't the a/c auto going to dial down as the entire cabin cools anyway? Just having the a/c blowing on me doesn't seem to be efficient in that regard. It feels good initially though.
  17. jtmhog
    jtmhog Member
    151
    The higher the temp. setting the less the A/C compressor runs and thus, less energy consumed. My 22 miles commute is mostly 60-70 mph with a few stop lights and usually no congestion (HOV lanes No. VA). Mileage with A/C @ 79F 47-48 MPG; w/o A/C, 2 front windows full open, 50-51 MPG. The variable that is unknown is the increase in drag with the windows down. Of course, the drag increases as the speed increases. The A/C MPG effect can be determined by conducting the following test. Pre-test conditions: warm-up car fully; flat highway; temperature greater than 85F; area where you can use cruise control for 40-50 miles; A/C set temp at least 10 degrees lower than outside temp to load compressor. Test: place car in cruise, set A/C, press reset on MFD, drive 20-25 miles, record MPG; turn off A/C including fans, open 2 front windows, press MFD reset, drive same speed and distance as with A/C on, note MPG. Report results to this forum. Improvements to test are requested. Test should be run at different speeds and outside temps.
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(kaysea\";p=\"110411)</div>
    with the air on, it will reduce the humidity, so that wouldnt be bad especially when the outside temp is 20+º hotter.
    as for me, i dont do hot very well so my mileage suffers when it gets hot. lately its been in the mid 80's, my air is set to 72º and my mileage is at 54.5 down from 60.5... oh well
  19. Anonymous
    Anonymous Guest
    Wow, you're good, Dave. I can get 60 if I don't run the a/c at all. That's not going to happen this summer, probably. But that's what it reads on days when it's cool out. It's still good enough, though, to be able tell coworkers that "yep, I'm only getting 52 right now". They hate that so I try not to bring it up too often. One coworker said "damn, I only get 42 and that's on my motorcycle."
  20. natural_tools
    32
    Dallas, TX
    Wow, I thought "I don't do well in hot either!" and then I read that you think hot is mid 80's. We call that spring. Still not sure why I moved here.
    Also, I think I've just hit my maximum MPG based on local road conditions. I get 53 at best and I'm no slacker... I don't see how people are getting 60. Though I'm excited because they finished road construction and reopened the road that goes entirely downhill at 35 mph to where I work.
