Which battery is which?
Discussion in 'Gen 2 Prius Main Forum' started by Kidd, Jan 1, 2008.
  1. Kidd
    Kidd New Member
    75
    Port Orange, FL
    Is the battery that's hidden in the rear hatch area the battery that is being charged on the MFD?
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Well, both batteries are hidden in the rear hatch area. The battery that's being charged on the MFD is the traction battery, which is under the rear seat and in the front of the cargo area (i.e. the part closest to the front of the car).
    The auxiliary (12V) battery, which is the one that starts the car, runs the lights, powers the radio, etc. is hidden in the back of cargo area on the right hand (passenger's) side.
    The 12V battery looks a lot like a smaller version of the batteries you're used to seeing in cars; the traction (~200V) battery is much larger.
  3. Kidd
    Kidd New Member
    75
    Port Orange, FL
    Duh ! I guess I did know that. I must have lost a few more brain cells than I thought, last night! I did not know that the 12 volt handled the radio and junk. What else does the 12 volt run?
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The 12V battery/bus runs everything except the two Motor/Generators, and the air conditioner.
  5. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I thought it was the traction battery that actually starts the engine and the 12V was responsible for the computers, lights, etc.?
  6. patsparks
    10,664
    567
    Adelaide South Australia
    The 12 volt battery runs very little really, only filling in where the inverter falls short, it fires up the inverter and computers then the inverter takes over. The battery smoothes the power supply during peaks in demand and powers accessories when not in the ready mode such as the interior lights and radio. It also powers the headlights if they are on after the system is shut down until the door is opened. It powers the security system also.
    I would say the traction battery is behind rather than under the back seat. The petrol tank is under the floor under the back seat.
  7. Betelgeuse
    1,460
    24
    New York, NY, USA
    I have always been under the impression that the 12V battery runs everything but the drive motors and the A/C. Perhaps you're refering to the fact that the traction battery charges the 12V battery when the car is in "Ready"? Here's a question that I don't know the answer to: if you were to disconnect the 12V batter while the car was in "Ready," would the headlights and the radio continue to work?
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    This experiment was done. Go to:
    http://techno-fandom.org/~hobbit/cars/prius-12V/
  9. Betelgeuse
    1,460
    24
    New York, NY, USA
    Cool. Thanks. So, I guess this means that pat is right; nothing runs off of the 12V battery while the car is in "Ready." The DC-DC converter directly powers everything while the car is on.
  10. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
    The same is true of most cars - you can usually disconnect the 12V battery while the car is running. While running, the 12V power is generated by the drive system - the alternator on a normal car, or the 200V hybrid system on a Prius.
  11. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    I wouldn't recommend doing this, however (disconnecting the 12V battery while the car is in "Ready"). You loose some regulation of the system voltage. I don't know how much regulation you loose or how much more susceptible the electronics would be to voltage problems, but I wouldn't want to find out. The results could be expensive! I suppose the design had to be done so the system would be ok (in case the battery failed).
    The engine is started by the inverter/traction battery. When starting the car you press the brake pedal and the system (brake booster) draws a 1/2 sec 40 Amp pulse from the 12V battery, then you press "Start" and it draws another 1/2 sec 40 amp pulse of power (putting the computers and electronics in "Ready"). After that you will see a current -into- the 12V battery ("float charging" it). The inverter 12 Volt system charger takes over (actually running at 13.8V).
  12. patsparks
    10,664
    567
    Never disconnect the battery of a vehicle with an alternator while it is running, you can damage the electrical system Same goes for Prius. The battery may not be providing power but it is a reservoir of electric energy.
    Edit, thanks David, I posted as soon as I saw about disconnecting batteries but you had it covered.
  13. Kidd
    Kidd New Member
    75
    Port Orange, FL
    I have to laugh at my ignorance. I originally posed the battery question and received these great responses. Most of which totally blast me out of the water with my next to zilch electrical and auto mechanical knowledge. Regardless of that fact, I am glad I was able to spark some obviously much needed attention on the battery question. Rock on dudes!
