Which cabin air filter should I use for prius prime?
Discussion in 'Prime Main Forum (2017-2022)' started by Tomca, Aug 8, 2022.
  1. Tomca
    Tomca Junior Member
    46
    CA
    hi all,
    After last maintenance, I start to smell smoke comes inside my car which never happened before.
    So I guess it's time to change the cabin air filter.
    I found two parts that fits the car online.
    Cabin Air Filter - Toyota (87139-0R030)
    Cabin Air Filter - Toyota (87139-58010)
    Could someone please tell me which one should I use, and if possible? what's the difference? I see one is much more expensive than another one.
    Thanks.
  2. Trollbait
    11,505
    I'm guessing the more expensive one has a carbon filter to get rid of odors.
    TGrracie and Tomca like this.
  3. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Either one would work. The less expensive Toyota OEM (87139-0R030) is just a paper filter but still costs an MSRP of $22.76 (street price can be ~$15). Very expensive Toyota OEM (87139-58010) has activated charcoal-infused paper that would help eliminate odor problems but costs an MSRP of $54.65 (street price can be ~$40). I use a much cheaper after-market filter that cost a fraction of the OEM filters. I had a rodent problem, nesting on the cabin filter, so I check the filter frequently and change it if I see any sign of rodents getting on the cabin filter which is now covered by a hard cloth.
    #3 Salamander_King, Aug 8, 2022
  4. Tomca
    Tomca Junior Member
    46
    CA
    Thank you very much for your answers.
    schja01 and Salamander_King like this.
  5. eatriceyo
    eatriceyo Member
    45
    32
    Honolulu
    i bought the washable reusable k&n cabin air filter. saves you money in the long run.
    Tomca and TGrracie like this.
  6. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    I only use factory filters.
  7. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    You don't need a cabin air filter. It is for your comfort, not any mechanical reason. The better ones may filter better, and that's what I buy, but any one will do the job. Spend your money wisely.
    What was the source of the smoke? If it was from the environment, then either the situation will be corrected or the charcoal filter will be a good option. If it was from your car...get that fixed!
    Mendel Leisk and Trollbait like this.
