Which car should I buy?
Discussion in 'Newbie Forum' started by carloss, Sep 14, 2013.
  1. carloss
    carloss New Member
    I'm looking to buy a Toyota Prius and was wondering which car would be considered to
    be in better condition: a 2005 with 106k or a 2009 with 122k mileage? The 2005 is 1000
    dollars cheaper with 1 year warranty on the hybrid battery and related parts. The 2009
    still has 28k warranty on these parts, which probably equals two years considering how
    much I would drive it. I don't know anything about the previous owners driving style and
    if it were city or highway miles. What are the thing I have to pay attention to for each car? I heard that a lot of maintenance is to be expected on Prius vehicles between 120k and 180k. Is this true? I hope you can give me some advice! Thanks!
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    The 05 is overpriced. I'd definitely buy the 09.
    No, the Gen II doesn't require a lot of maintenance after the 120K mileage mark. The spark plugs, transaxle fluid should have been changed already. The inverter coolant and gas engine coolant should be changed at 180K miles. That's it. Not much.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,589
    5,888
    Texas Hill Country
    without question the 2009. Particularly if manufactured after March 2009.
    51,141
    welcome to priuschat! 05 and 09 are same gen, but i also would do the 09. all the best!(y)
  5. carloss
    carloss New Member
    Thanks for the advice, I will go for the 09 then! I was also wondering, since the 09 already has quite high mileage considering it's only 5 years old, is there anything particular that I need to pay attention to or that I should get checked out at a mechanic before buying?
  6. bisco
    51,141
    the best way to check a prius is to reset the mpg meter and take it for a good long ride under various conditions. if you get 50 mpg or better, you're good to go. if not, drop it off and don't go back.
  7. sportcoupe
    sportcoupe Junior Member
    44
    Why would you expect a first time prius driver to be able to get 50+ min average mpg on a test drive of a 2nd gen car? That exceeds the DOE's 46mpg combined rating by more then 10%. I have only had my prius for a couple of tanks now and only can manage 48 mpg average tank fulls driving with some care. I know I'm not alone in that either.
    Jamesb93612 and xpcman like this.
  8. bisco
    51,141
    because i did. 2004, 65 mpg on the stimpmeter, right out of the shoot.;)
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    The car in your information box is not a Second Gen Prius. (2004 to 2009) It make sense you can get 65 out of a PIP first day, it is a skill that is learned in the Gen 2.
  10. bisco
    51,141
    now jim, you know i've been around the block a few times since 2005.:)
  11. carloss
    carloss New Member
    I'm going back for a test drive this week so I'll definitely check it out. The dealer had driven the car for 100 miles on the highway and it had 43 mpg after that drive. I don't know what his driving style is though. Do you think it's bad mileage?
  12. bisco
    51,141
    it all depends on speed on the highway. there's a chart here somewhere that shows mpg v speed. i think 43 would be around 70 mpg iirc, but not positive. it also depends on a/c use, tyre pressure, hills and etc.
  13. mikefocke
    3,899
    1,755
    Sanford, NC
    100 miles on the highway at 55, 65 or 75?
    On the flat or up and down hills?
    Altitude?
    Pulse and glide or just drive?
    AC on? Heater on?
    Too many variables to judge without knowing.
  14. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Just keep your highway speed between 55-60 miles per hour. You should get 45 mpg if you don't mash the gas pedal. in down use gentle acceleration and again you should get 45 mpg on a 5-10 mile loop. If you take it on a 2 mile test drive you may very well get as low as 30 mpg while the car warms up.
