Which HID headlight is recommended?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Woodworker, Dec 25, 2010.
  1. Woodworker
    Woodworker New Member
    Pennsylvania
    My '04 Prius drivers side headlight is intermittant. I've read that this is caused by the headlight going bad in most cases. I pulled the bulb and found it to be a OSRAM Xenarc D2R. Is this the OEM bulb?
    I have been very satisfied with the bright white light and got many comments from passengers. Where do you recommend buying a replacement and is there a better brand to get?
    Thanks for your help. I did search for this but could not locate the exact answer I was looking for.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Yes
    Philips 85126 on Ebay. Look for a seller with high feedback numbers.
