Which is heavier?.......
Discussion in 'Fred's House of Pancakes' started by hyo silver, Apr 13, 2011.
  1. a pound of feathers
    23.1%
  2. a pound of gold
    0 vote(s)
    0.0%
  3. neither; they weigh the same
    53.8%
  4. I hate these stupid questions
    23.1%
  1. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    ...a pound of feathers or a pound of gold?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. richard schumacher
    7,664
    1,047
    United States
    The pound of feathers is heavier. Feathers are weighed with avoirdupois pounds; gold is weighed with Troy pounds = 144/175 avoirdupois pounds.
    Dontcha just love traditional systems of weights and measures? :_>
  4. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    I knew somebody was going to bring this up which is why I hate these stupid questions.
  5. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    This kind of thing reminds me of a cynical speculation a friend and I once had that if McDonalds were to introduce a 5 oz. burger they'd sell more of them by advertising them as the "Lite Fiver for those who can't eat a whole Quarter Pounder".
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    What if it were an ounce of feathers and an ounce of gold? Which is heavier then?
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    This is like asking if Englands has a 4th of July...:)
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    If they have the same mass, then it depends on the gravity to which each is subjected. Weight is a force and therefor dependent on gravity. Mass is independent of gravity.
    Tom
  9. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    An avoirdupois ounce(ie- feathers, commodities) = 28.350 grams.
    A troy ounce(ie- gold, jewels) = 31.103 grams.
    An apothecaries' ounce(ie- drugs) = 31.103 grams.
    2 people like this.
  10. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    How about !
    Put both in a plastic ziplock bag, squeeze the air out, and drop both at the same time from a height of 100 feet.
    What will happen?
    My prediction: Gold will land second, because of smaller volume. When both projectiles reach terminal velocity, their speed will be slightly different due to air friction, around the ziplock bag.
    The pound of feathers might "fill" the ziplock bag better, making a rounder shape, less air resistance. The pound of gold, being quite small, even with the air taken out, will flop around creating drag.
    My guess is the gold will arrive 1/4 of a second after the feathers over 100 feet. If dropped from 30,000 feet, terminal velocity of both objects will act for a longer period of time, both packages will arrive many seconds apart.
    Dropping the same objects on the moon, no matter the distance, both arrive at the same time since terminal velocity won't come into play.
  11. krelborne
    krelborne New Member
    295
    Alabama
    I do not know. How many feathers can you buy for a £?
    2 people like this.
  12. qbee42
    18,058
    3,079
    Northern Michigan
    But that doesn't answer the OP's question. All that does is demonstrate that gravity accelerates all objects equally, regardless of weight.
    Tom
  13. markderail
    2,260
    163
    So far I like krelborne answer the best, which would mean feathers. One £ buys precious little Au (79) these days.
    Bird feathers are probably so cheap you could use it for insulation, great cash down on a house.
    Hyo must be getting a kick out of these posts.
  14. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, I am. :)
    This is one of my favourite questions. It serves both to illustrate the absurdity of archaic systems of weights and measures, and to reveal a little something of how people think.
    I start with the ounce, having to explain that 'yes, it's a trick question, but there really is a correct answer. And it's not that they're both the same.' After going through the Avoirdupois and Troy difference, and letting that almost sink in, I ask about a pound of feathers and a pound of gold. 'Oh no, you're not fooling me again with that trick.' :p
  15. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    One pound of feathers = 456.48 grams (16 ounces)
    One pound of gold = 373.236 grams (12 T ounces)
    Thanks to Pri4us for the gram :thumb:
