Which is more efficient, hydrogen fuel cell or battery electric vehicle?
Discussion in 'Tesla' started by el Crucero, Feb 8, 2019.
  1. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Here is a simple chart provided by physorg.com that explains the efficiency of both models, that even I can understand!
    3PriusMike likes this.
  2. 3PriusMike
    2,964
    2,316
    Silicon Valley
    They are being overly generous for the hydrogen case. 75% efficiency for hydrolysis may be achievable, but it would be the best case for high volume production. It cannot really be assumed that this would be the case for every refueling station since they have to be located in convenient locations. And where does the electricity come from? Is the hydrogen plant right next to the power plant? If not you need to add in some electric transmission losses.
    In the case for electricity it should just be noted that if you happen to have solar located nearby, then your transmission losses are less.
    Also, for EVs, pretty much anyone and everyone can achieve the numbers they show with the primary variable being the distance to the power plant, thus varying amount of transmission losses, typically, nationwide, about 8% to 15%. (The 15% being during high summer demand where power is moved long distances, most likely)
    Mike
    #2 3PriusMike, Feb 8, 2019
    Raytheeagle likes this.
    49,398
    yeah but, the hydrogen tree is missing the: 'miracle happens here' step, then it beats bev's
