Which lights are LEDs (2022 Limited)?
Discussion in 'Prime Accessories and Modifications' started by Darien Day, Jan 26, 2022.
  1. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Anyone know which lights in the 2022 Limited are NOT LEDs?
    I'm trying to piece together a kit to replace those. I'm not sure if the Reverse LEDs are needed since I don't know if they are already LEDs (I didn't select them in the screenshot):
  2. Elektroingenieur
    2,515
    3,264
    Three Touring
    See the Owner’s Manual (PDF), page 734, for a list.
    Darien Day likes this.
  3. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Thanks for that. Is there another page that says that lists which are LEDs? Or are they all halogen?
    Elektroingenieur likes this.
  4. Elektroingenieur
    2,515
    3,264
    Three Touring
    On page 657, Toyota writes, “The lights other than the back-up lights each consist of a number of LEDs.” Looking through the parts catalog, I don’t see any incandescent lamps on the car that aren’t in the list on page 734.
  5. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Hmmm, so they are all LEDs except for the backup lights.
  6. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    All the exterior lights except Back-up lights are LED.
    I believe most of the interior lights are incandescent bulbs as shown on the list except the Shift lever light which is LED. The footwell lights may also be LED, but I have not confirmed this.
  7. Salamander_King
    10,975
    8,873
    New England
    Here is where the manual says that except for the back-up lights, all other exterior lights are LED.
  8. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Says IF EQUIPPED, and that is talking about Exterior lights. All interior lights are incandescent, I know because I replaced them with the lights from the Precision. I didn't replace the backup lights though. Hint on Vanity lights, if you replace them, they had a tendency to pop out with use of Sun Visor, fixed problem by roughing up the LED metal blades that plug into the socket just a little bit.
    Another hint for you to prove they aren't LED, Incandescent aren't bright and seem a little yellow.
    #8 Hidyho, Jan 28, 2022
    Storm88000 and Darien Day like this.
