Which MFD do I have?
Discussion in 'Gen 2 Prius Technical Discussion' started by arcocelli, May 7, 2008.
  1. arcocelli
    arcocelli New Member
    Baldwin City, KS
    Hello!
    I've read about the problem with failing MFD's. I have a 2005 with no info button on the steering wheel. Is there any way to tell if I have one of the older, possibly prone to fail MFD's or the newer fixed one that is in the new 2005's?
    thanks!
    Brett
  2. richard schumacher
    7,663
    1,038
    United States
    Maybe you could pry that out of Toyota customer service using the VIN? I don't recall ever seeing the range of affected VINs.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    Check this link:
    http://techno-fandom.org/~hobbit/cars/mfd/
    Hobbit has the TSB chart which will tell you if your MFD is the potentially bad one or not by the P/N. You have to remove the MFD to see the P/N.
    He even tells you how you could fix it if you are handy with a soldering iron. ; )
