which mode to use in prius prime
Discussion in 'Prime Main Forum (2017-2022)' started by Cavi, Nov 1, 2021.
  1. Cavi
    Cavi New Member
    Red Bluff Ca
    2022 Prius Prime
    so I have a new 2022 prime, of the three modes normal, eco and power i would assume that eco will give the best milage, but I heard that the power mode gives the most regen. So is the eco really the best? is there much difference in milages between the 3 modes?
  2. Tideland Prius
    16,155
    Assuming you don't change your driving style (and everything else is the same - terrain, temperature, traffic etc), then yes Eco can help improve EV range and/or mpg. Eco mode automatically puts the climate control in "Eco Heat/Cool" as well. However, you can manually enable that in normal or PWR mode too.
    Changing the driving mode does not change the regen so Eco, normal and PWR function the same when it comes to regen.
    If you're new to Prius, Eco mode can help train your foot to be more gentle with the throttle because Eco mode dampens the sensitivity of the accelerator pedal.
    Tightwad77 likes this.
  3. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Mode means more than one thing. The mode you asked about is all about the sensitivity of the accelerator pedal. Eco gives a slower start for a given pedal push, and may add some range. Normal gives a brisker start for the same push, and Pwr has the most giddy-up for the same pedal push. We usually use Normal, but switch to Pwr on the freeway when we might need to squirt into an opening in traffic. Try them all and see which suits your driving.
    The other totally separate Mode setting is for EV, EV Auto, or HV. EV does everything using the battery first, then switching to the engine when the battery is depleted. You can leave it this way all the time. It's smart. EV Auto uses the engine on a hard pull even if battery power is available, and may give slightly better mileage if the hills are steep. HV is standard hybrid which is a little battery and lots of engine use. I've never found a reason to switch to this, and the EV mode does it automatically for me.
    Ingapone likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Congrats on the new ride. You can get good economy in any of the three modes depending on how you drive. As mentioned, it remaps the throttle sensitivity. Here's a chart from previous generations. Gen 4 is similar if not identical
    I find that, if I'm driving slowly (45 mph or less) in EV, Eco gives me very fine control over the m/kWh I'm getting by allowing me to keep a steadier speed. I would suppose that at highway speed in HV mode, you'd have a higher throttle opening and maybe it might be better in Normal or PWR since they have shallower slopes at higher accelerator openings. But that's a guess since the graph doesn't correlate speed with throttle position.
    Tideland Prius and dig4dirt like this.
  5. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    I devoutly wish Toyota called the two types of "mode" something different.
    Pedal Sensitivity, maybe?
  6. jerrymildred
    11,511
    14,113
    Tampa, FL
    But "pedal sensitivity" isn't all they affect.
