which noise is which?
Discussion in 'Gen 2 Prius Main Forum' started by cwerdna, Jul 4, 2006.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'm not sure if this is a FAQ, but does someone know what's happening w/each of these noises? Maybe the service manual has a key to all the noises?
    When I'm leaving my car, I hear the hiss, buzz for a few seconds, then a click. I always figured that was sounds of the thermos bottle opening and coolant being pumped. I see some discussion at http://priuschat.com/index.php?showtopic=8299&st=0&p=83466&#. Maybe I'm actually hearing what's describe at http://priuschat.com/index.php?s=&showtopi...indpost&p=83446?
    Another I've sometime heard sounds like a repeated pumping noise (almost like a hand pump going a few times....maybe 10-20 cycles of it). I think I've heard it after pressing Power but maybe at other times. What's that?
    When using the brakes, I sometimes (usually) hear a buzzing motor sound (afterwards or while braking) similar to the 1st buzz I talked about. What's that again?
    My car came w/three tags on strings, two have notes about noises. One says "IN THOSE CASES SUCH AS THE TIME OF ENGINE STARTING AND A SHORT TRIP AFTER THE ENGINE IS STOPPED, MOTOR WATER PUMP WILL WORK FOR A MOMENT, BUT THIS IS NO PROBLEM.
    THIS IS FOR THE PREPARATION FOR GOOD EMISSION." Are they referring to the 1st noise I heard or the pumping or something else? I've also seen a references to this in the manual.
    The other tag says "Approximately five hours after the engine is turned off, you may hear an electric motor sound under the luggage comportant for several minutes. It is not a malfunction. It is the sound of a pump performing a fuel evaporation leakage check. See Owner's Manual for details."
    I've never stood at my car 5 hours after shutdown. What does this sound like?
  2. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(cwerdna @ Jul 3 2006, 11:00 PM) [snapback]280865[/snapback]</div>
    all great questions...I will try to help, but others with more technical knowledge can probably answer with more detail:
    -First you hear the coolant noise
    -Second you hear the brake pressure noise
    -I am not sure about the repeated pumping noise, unless you are hearing the coolant being pumped back into the engine right after you hit the start button.
    -Brake buzzing noise, I believe this has something to do with regeneration / use of the electric brakes (others can elaborate more)
    - Yes, the Japanlish is trying to say that the coolant noise will happen each time you shut down no matter how long your drive
    - Yes, I have heard the electric motor noise (fuel evap leakage check), and it pretty much sounds like a little buzzing electric motor (although mine is only on for a few seconds)
  3. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(mssmith95 @ Jul 3 2006, 11:14 PM) [snapback]280874[/snapback]</div>
    The proper name is Engrish. ;) Check out www.engrish.com for some funny examples. :)
    I saw some interesting Engrish while in Japan like "Chofu The Dinning" [Chofu is a city] and "mind the burn" on some lights in a hotel along w/the usual mixing up of Ls and Rs.
  4. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(cwerdna @ Jul 4 2006, 02:00 AM) [snapback]280865[/snapback]</div>
    Yup. Sounds like the coolant being pumped into the thermos to me.
    I don't know what that is, but, as mssmith95 suggested, it would be logically consistent with that being the coolant being pumped back into the engine.
    This is definately the brake accumulator pump. This actually really freaked me out when I first got the car and I thought I was going to have to take it back for service. I read a good description on this board at one point that I'll now try to recreate, but may screw it up slightly. Basically, on a normal car, brake pressure is kept up by the (gas) engine. The "challenge" with the Prius is that the gas engine isn't always running (and you usually want to have brakes, even when you're in EV mode :) ). So, that means that you have to use an electric pump to keep up the pressure in the brake lines up.
    You can easily recreate the sound by pumping the brakes while the car is in Park. Just pump the pedal 3 or 4 times and you should hear the brake accumulator pump.
  5. busyrosy
    busyrosy New Member
    113
    Bay Area, CA
    We need a Prian - English dictionary, LOL ;)
  6. elcholoperuano
    elcholoperuano New Member
    I'd like to elaborate on the fan/pump noise that cwerdna was hearing. Mine happens every time the fan comes on and it sounds like it's running fine then it sounds like it's sick and then back again repeatedly until it shuts off.
    I just took it in to the dealership thinking that maybe it was going out but after looking at it they said it's normal (though I only remember hearing it this "new" way for the past couple of weeks). I know that you might think that maybe I'm just not very observant but this is the first car since my very first car ever that the fan keeps running even after the car has been turned off. This being the case, plus the fact that it's on the driver side and I walk past it every time I get out of the car, yes I notice it every time.
    They also said that many of their customers have been complaining about it and that maybe there will be a recall on it but I wanted to get other owners' feedback on it.
    I hope I've explained myself enough, if not, please let me know and I'll try to elaborate more : )
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As I've posted before, there are two facing pages in the owners manual about the sounds Prius makes. The gist of all that is "the odd noises that you hear are normal". ;)
    When you turn the car on or off, you will hear a faint clicking of the valves setting and then the whir of the coolant transfer pump, putting warm coolant into the thermos or taking it out. If it squeals the bearings are going and it needs to be replaced (warranty).
    When you start the car you will hear a very brief pump sound, and you will hear it about 1 in 3 times you step on the brake pedal. It's the brake fluid pressure accumulator pump for power brakes. Prius needs this as it can't rely on engine vacuum for power brakes, as the engine doesn't run all the time like it does in guzzlers.
    After you have shut the car off and it has been sitting for awhile (more than a few minutes) you will hear the odd click. This is various relays opening and closing, particularly if you have the FOB in your pocket. The car senses you are near and -may- want to operate the car. It "gets ready". This is also in the owners manual.
    I've so far never heard the five hour fuel pressurization test so I can't describe it for you.
  8. elcholoperuano
    Okay so that's what I would like clarification on. The dealership said that the sound I am hearing is the "purge valve" and proceeded to try to make me feel like an idiot by stating that this is a "totally different technological vehicle". No s**t but the sound of the pump isn't supposed to change from high to low like a kid entering adolescence is it? Personally I don't think so, but then again I don't work for Toyota.
    As far as all the other noises, they make sense. I understand them and they don't bother me. I just know after walking in front of my own car for a year that when the fan is on, transfer pump, purge valve or whatever else it is that still remains running after the car has been shut off, it didn't (before) make the sound it's making now; which is the "sick" sound it makes until it eventually shuts off ("sick" of course being the sound of the pump, or fan, or whatever it is changing its pitch)
    So David, if what you're saying is true, that likely it's a bearings issue and should be replaced what can I, as already having been told by my Toyota dealership that it's "normal noise", do?
  9. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    You can try showing them this TSB. Humming is okay, but it's not supposed to sound squeaky.
