Which Of These Gas 87, 89, 91 Do You Guy Use?
Discussion in 'Gen 2 Prius Fuel Economy' started by 08Prius, May 30, 2008.
  1. 08Prius
    08Prius New Member
    26
    Long Beach CA
    I own an 08 Prius and always filling up with 91 rated gas. I heard some of you guys saying that filling up with a low rated gas (87) is better.
    Please advice to this. I don't think i can spend more money on high rated gas (91) due to the gas price is going up.
    Thanks
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    87 is what the engine is designed for. Anything else is a waste of money.
    87 is not a "low rated gas" . . . 87 is its octane rating. It does not mean it is inferior gas!
    Maybe I should try plugging my computer into the 220 outlet . . . maybe it will go faster.
    Or better yet, I think I will put jet fuel in my Prius on its next fill-up . . . because everyone knows jets go faster. :eek:
  3. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    wow. someone actually buys that stuff? wow
  4. rkskeet
    rkskeet New Member
    91
    State College Pa
    87 Octane is what you should use...
  5. loftishb
    loftishb HughB
    16
    Virginia Beach
    87. The engine has no issues with 87, so no need to buy a higher octane (my F150 is another story).
  6. Sufferin' Prius Envy
    3,998
    Yeah . . . people who buy Smart Cars.
    (I read where the Smart uses premium. IS THAT A SMART DESIGN ?????? :der:
  7. Tammy7287
    Tammy7287 Junior Member
    83
    Maple Valley, WA
    I use 87.
    My Passat's owners manual said that it needed Premium because of the Turbo but it still only got 87. lol
  8. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    87 -- runs great, sounds fine, getting 65 mpg (MFD) now that it's warm.
    But at last fill-up, when my usual station had signs on the pumps saying "Up to 10% ethanol," I went to a non-ethanol station & thought I'd better check owners manual & PC gas threads.
  9. Yankees251
    Yankees251 Black Touring HI Package
    96
    Danbury, CT
    Thanks for buying Premium for all this time, helped keep my 87 a bit lower priced by giving the oil companies a bit more profit. Keep buying 91, heck i hear 93 is even better.
  10. Voidvoice
    Voidvoice New Member
    55
    New York City
    have a question regarding this, a friend of mine insist premium increase FE, he a BMW that require premium, i dont think it is the case, any fact on this?/
  11. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I'm willing to bet his BMW gets crappy FE.
    The Prius manual says the car should get 87.
  12. Yankees251
    96
    Danbury, CT
  13. loftishb
    loftishb HughB
    16
    Virginia Beach
    Here is a good site for explaining: What Octane Rating of Gasoline Should I Use?
  14. racerbob
    racerbob Member
    138
    S Florida
    High octane is harder to ignite. It's only purpose is to prevent detonation (pinging) in high compression engines. Prius functions as a lower compression engine and is happy with 87. You are wasting money and increasing emissions by not burning the harder to ignite fuel completely.
  15. 08Prius
    08Prius New Member
    26
    Long Beach CA
    I tried to put 87 and my car running not so strong enough and that's why i want to know what prius owners put .
  16. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I use 85 octane because that's "regular" here in CO. It's an altitude thing. Don't put higher octanes in, like others have said, it's a waste of money. The BMW might get better mileage with higher octane if it's designed to take advantage of the higher compression ratios that are possible with higher octane fuels. It's not because there's more energy in higher octane petrol.
  17. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I use 87 for the Prius because that is what it is designed for. My wife has the 1.8T version of the Beetle it is designed for 91 octane gas not because of the turbo but because of the compression. Performance engines need the higher octane so that the gasoline doesn't explode before the piston compresses fully which causes a knock (very bad). I have a Vag-Com for her VW which allows me to see all the readings from the ECU's. 87 octane in it makes the knock sensors go to the very limit of their automatic adjustment.
    Howstuffworks "What does octane mean?"
  18. chinoloco93
    chinoloco93 New Member
    30
    Mt. View California
    87 octane is all thats needed. Anything else is a waste.
  19. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    You guys are all far too kind to the OP, where are the sarcastic questions about using the 'search' function, about how this topic has been discussed repeatedly, about how there's a lot of good info in the owner's manual that came with the car? And then follow up with asking whether one should use dino or synth oil, or how does one disable the reverse beep, or what are the best tires for the Prius? C'mon, fellas, the OP deserves a severe flaming!!
  20. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    getting my wet noodle ready for the flogging...
