Which oil weight???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mwc716, Jul 1, 2008.
  1. mwc716
    mwc716 New Member
    16
    Atlanta, GA
    I'm about to start changing my own oil now that the dealer as screwed me yet again...Another overfill. I plan on using Mobil 1 with Mobil 1 filter. After much research on here, what I'd like to know is:
    I cannot figure which weight oil to use! I know Toyota specs 5w30 but I've seen so many different people using other weights that I'm confused. I don't want to adversely affect MPG but also want to get the most bang for my buck, ya know? It's pretty warm here year round so I do not know if that changes anything.
    Any clarification would be great!
    BTW: I have some UOA kits on order from Blackstone so I can test the Toyota oil and see what the change is to the Mobil 1. Can't wait!
  2. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    You live in GA, USA where the summers are hot and the winters mild. Going to a 20 wt oil would see little benefit in fuel economy or cold start wear reduction. I would stay with 5W-30 Mobil 1 EP for longer drain intervals which are better for the environment. People get decent 10,000 mile intervals on UOA with this oil.
    If you want to go to a longer interval, than Amsoil 0W-30 SSO would be my recommendation.
    Rumple
  3. mwc716
    mwc716 New Member
    16
    Atlanta, GA
    Sounds good! Thats what I was thinking. Know of any place to get the Mobil 1 EP for a discount?
  4. uvm1969
    uvm1969 New Member
    39
    I would recommend the 0W-20 synthetic motor oil by Penzoil, called Penzoil Platinum. I get better mileage than with the 5W-30 I had been using, and it easily handles the heat here in Texas.
  5. mwc716
    mwc716 New Member
    16
    Atlanta, GA
    Makes me nervous to use such a light oil. Could there be any long-term problems? If so, what?
  6. richard schumacher
    7,663
    1,038
    United States
    Uh, yeah, you would likely wear out the engine faster. Use what the designers of the engine advise.
  7. Rest
    Rest Active Member
    1,210
    53
    CA
    If your vehicle is still under warranty then I would stick with the weight Toyota recommends.
