Which one: Gen 4 vs Volt vs C-Max?
Discussion in 'Gen 4 Prius Main Forum' started by BuckleSpring, Jun 12, 2023.
Which one would you buy?
Poll closed Jun 19, 2023.
  1. 2015-2016 C-Max
    1 vote(s)
    11.1%
  2. 2014-2015 Volt
    0 vote(s)
    0.0%
  3. 2016 Prius w/ higher mileage
    8 vote(s)
    88.9%
  1. BuckleSpring
    BuckleSpring Junior Member
    45
    16
    United States
    I'm helping my father shop for a replacement for his daily commuter, and have been debating on what to get, and it's come down to essentially 3 options:
    • 2015-2016 C-Max
    • 2014-2015 Volt
    • 2016 Prius
    The CMax is a bit of a wild card: we've never driven one, only ever seen maybe one or two, and there aren't any for sale within 150 miles to look at or test drive. Benefits over the Prius being more space(?), more power, higher seating position, and better amenities from what I've read. Don't really know much about their reliability, but they haven't held their value well and we can easily find 2015-2016 SEL's for ~10k with under 115k miles. Anyone here that has owned both a Gen 4 and a C-Max care to comment?
    The Gen 4 Prius is... a Prius; We've owned 3 Gen 2's that have been absolutely flawless besides some battery maintenance, they eat up miles and abuse and keep coming back for more with no complaints. Downside of this option being that for his price range, they're going to be high mileage, but on the other hand I have absolute faith in their reliability (minus the exhaust heat exchanger issue), especially since they're not old enough for any battery issues yet I would hope/assume. And even when/if it does break, there's plenty out there to get parts from. Only real downside besides mileage would be the power, his commute involves a ~1250ft elevation climb at 70+ mph for about 10 minutes, might be hard on the car to do that every day.
    The Volt is an interesting proposition. We set up his garage for 240V years ago, and could easily install a 50+ amp EVSE and have it mounted at the front of the driveway. His daily commute is ~80 miles round trip, meaning even though there isn't charging at his place of work yet, he would still be able to drive at least half the trip on EV power, and use about a gallon coming back (until they install some EVSE's at his place of work, which I assume they will at some point because it's a Federal building). Downside of this being that it's lower w/ a lower roofline (he's getting older and his knees aren't as good any more), only 4 seats, less cargo room, and honestly having a much larger battery that can degrade and give issues over time and cost more to replace, although I don't know anyone with a Volt and haven't done much research into degradation on the late Gen 1's.
    49,500
    they're all good cars from what i've read. i would encourage him to buy the one he likes best after test driving.
    80 miles a day is a lot of miles to put on any used car, depending on how long he plans to keep it.
  3. BuckleSpring
    45
    16
    United States
    Yeah, that's kinda the issue. We live in the middle of nowhere and can't find any of the above to test drive, minus a Gen 4. I'd say he would plan on keeping it ~5 years, and he averages ~37.5k miles a year.... I did suggest to him that that is asking a lot of a used car, but he just bought my little sister a new Corolla to go away to college with and doesn't want to have another car payment, hence just buying something under ~12k outright. His current commuter is simply falling apart and I doubt it has more than a few months left before it just dies or needs an expensive repair and isn't worth it.
    I've been leaning away from the Volt just due to the fact that that's a lot of miles and time to trust the battery pack, and a replacement/refurb job isn't a fairly simple operation like the Prius, even though it would likely save him a lot of money on fuel.
    49,500
    volts have a great high mileage track record, idk about c-max. neither one is made anymore, and gen4 prius should be at least as good when your talking 300,000 miles. he will still have to plan for major expenses down the road, but the prius might be his best bet.
    the other issue is a reasonably priced hybrid mechanic v the dealership repair gouging. it doesn't take many repairs to offset gas savings over a non hybrid.
  5. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    Depends on if he can plug into a 110 volt outlet at work.
    make sure he finds the car as comfortable and that whatever he puts into a car fits.
    Generally you have
    Volt - EV Range & Comfort
    Prius - Fuel Economy & wheel chair storage
    CMAX - Room but storage may not be as good as Prius, economy and range worse than both
  6. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    Only ONE of the cars you are considering has a consistently high record of reliability. HOWEVER, that one is the one that is going to cost you the most money. One of the others comes from a company that has a very poor reputation regarding reliability.
    Perhaps the wiser choice would be to buy a non-hybrid/electric vehicle that has a very high reliability rating from the manufacturer of the vehicle you are looking at that also has a high reliability rating. In other words, you might want to consider a Toyota Corolla non hybrid. JMHO
    In addition, (again, FWIW, from a former owner of 7 GM vehicles) I wouldn’t touch the Volt with ANY pole!
    BuckleSpring likes this.
  7. BuckleSpring
    45
    16
    United States
    I'm not too worried about the mechanic part, we do all of our own work. I've done probably over half a dozen Gen 2 battery refurbs and installs, put a transmission in one, and have access to Techstream, a lift, garage, etc. Not really a concern
    Negative on the 110v outlet according to him, they are planning to install a handful of Level 2's in the parking garage but not until 2025
    We have considered some non-hybrid options, although he doesn't like the Corolla/Sentra/Versa/Fit or really any of the super econoboxes, especially as he's getting older and wants some comforts and amenities they don't offer, also hard no on any non-eCVT CVT. He likes the smooth quiet experience of Hybrids (I've let him borrow some of my Gen 2's for a few days at a time while his daily has been out of service for one reason or another). Some other non-hybrid options we've considered would be a 2014-2015 Mazda6 and Inifiniti G35/G37
  8. Rmay635703
    2,594
    1,612
    2013 Chevy Volt
    The most efficient (least gas + electricity) on that commute would be the Prius.
    Most thirsty the CMAX
    The Volt is borderline
    His trip theoretically should use a full battery + 1 gallon gas
    But will really depend on the battery condition, tire type and temperature + speed
    70MPH+ is not good for efficiency going up, long downhill glides are the volts friend far beyond the Prius. Very smart trip planning could give the volt an edge or a disadvantage. Word of caution never go up a mountain in a volt with an empty battery .
    Volt is likely the most enjoyable of the group but he should check out the seats and storage first.
    Meh the majority of the Volt complaints have to do with incompetent dealers overcharging, no different than the problem affecting the Prius about a decade back.
    There is a vibrant dir volt community to cheaply take care of any issue you might encounter, 400,000 miles later several have no complaints.
    #8 Rmay635703, Jun 12, 2023
  9. Mr.Vanvandenburg
    1,064
    370
    2020 Prius Prime
    Those year Volts require premium. Then there is the price and todays market for hybrids. I think the CMax hybrid of those later years is supposed to be good. I believe of the three the Prius will be most economical and best. The CMax plug in has a compromised cargo area. The regular hybrid is less compromised but still has a raised floor. The 2016 Prius has a great cargo area and the only one with a spare tire. The Prius has a much less expensive tire size.
  10. Rmay635703
    2,594
    1,612
    2013 Chevy Volt
    I have 144,000 miles on cheap KT88e15 gas with my 2013 Volt, at my mild 1200Ft elevation I see no difference between it and expensive premium
  11. Leadfoot J. McCoalroller
    7,176
    6,723
    Pennsylvania
    2018 Prius c
    Then you're probably also too far away from useful repair resources for all but the Prius. You're not talking about new cars, you'll need somebody who can work on them eventually.
  12. Mr.Vanvandenburg
    1,064
    370
    2020 Prius Prime
    The first gen Volt requires premium, not recommended, required. You can put in regular to save 30-40 cents per gallon it is your business. It still requires premium. You bought the Volt at what mileage?
  13. Rmay635703
    2,594
    1,612
    2013 Chevy Volt
    I save 80 cents- $1.50 a gallon 88e15 vrs 91 premium is extraordinarily expensive in this area.
    I bought at 34 miles on the odometer and have 80% gas miles
    I have the word of the engineer who designed the car and the fact there is an 87 octane tune in the ecm. Completely a non-issue, per my scanner at 1200ft on 88 (not rug) the car still has nearly identical timing as premium and no knock events.
    You supposedly loose gas MPGs running lower octane but it’s within the margin of error .
    Well worth saving nearly $10,000 in unnecessary fuel costs over the last 144,000 miles.
    88 is on its own pump and is typically 15-30 cents a gallon cheaper than the RUG shown.
    #13 Rmay635703, Jun 14, 2023
  14. ETC(SS)
    6,555
    Who does your maintenance?
    How much is gas?
    What are the real-world availabilities for these cars?
    I have 4 GMs in the driveway, and about 200k miles in G3's.
    Personally I'd go for the '16 Prius.
    Yeah,
    They're uglier than the nightly news but the real-world availability for the Volts is really really low, and I would not wish a C-max on anyone who is at the tender mercies of a Ford service department.
    Toyota's service departments are much, MUCH worse, but then they don't require as much service, and the G4 has been pretty reliable.
    We have some "Max's" in our fleet locally and they tend to be hangar queens.
    Both of my old Priuses are still in service after 20++ years and well over 200K miles each.
    Good Luck!
    Let us know how it shakes out.
    Rmay635703 likes this.
  15. Trollbait
    11,563
    GM called for premium mostly for concerns over what could happen to the fuel sitting unused in the tank over time. If the sealing of the tank didn't remain tight as designed, the octane level would drop. Filling with premium ensured the octane would still be above the absolute minimum for the engine to safely operate.
    The compression ratio of the Volt engine is just 0.1 higher than the regular octane fueled 2.5L in the 2016 Camry. Turbocharged siblings in the Cruze and Sonic called for regular. Naturally aspirated siblings in Europe called for the 91 equivalent, but produced 16 to 56 more horsepower than the Volt. Calling for premium for the Volt could have meant slightly better EPA results in fuel economy testing.
    If the engine is being used daily, as in this case, using regular shouldn't be an issue.
  16. Mr.Vanvandenburg
    1,064
    370
    2020 Prius Prime
    That’s fine, but in 2016 the redesigned Volt went to regular on the new engine, and has the same gas storage situation. The Prime has the same gas storage situation and uses regular. The Volt made sure the gas didn’t sit unused over a year or the engine would run to burn the gas, don’t think the Prime is as aggressive with that, and uses regular.
    Anyway all I said was GM wants premium only to be used as a comparison tool to the other two cars. They do say premium, there is no question. I had one a 2014, and to keep it simple, went by what the book says. It didn’t have to turn into anything at all with all this talking. Maybe it’s this product sensitivity thing, one against another.
  17. Animal Mother
    Animal Mother New Member
    Georgia
    One think to keep in mind is the cost to replace the battery pack. For a Chevy Volt it runs about $6k, for a Prius it runs about $2k.
    I have an 80 mile commute as well and test drove both a Volt and a Prius. I went with the Prius and I’m glad I did.
  18. BuckleSpring
    45
    16
    United States
    Again, not worried about the mechanic part. We have a lift, do all of our own work, access to Techstream, can easily install a new engine or transmission if needed, etc. The main concern is parts availability, for which we've both decided against the Volt. There just aren't enough around within a reasonable distance to get used parts from, and who knows about the battery as it ages.
    He does his own maintenance within reason (oil changes, brakes, etc), but usually calls me for anything more involved, like swapping a battery pack or transmission or etc, whatever he ends up getting will never see a dealer service department regardless of the issue. Gen 4's and C-Max's are way way more available than the Volt, and we've kinda decided against it in part for that reason. Assuming you've driven both, what do you like about the G4 over the C-Max or vice versa?
    Yup, that's the main reason we've decided against the Volt. Newest one in his price range is 8-9 years old, and assuming he'd keep it for another 5 years or ~150k miles.... that's a $7k+ repair bill just for the part. In the G4, even if the battery *were* to fail, there's so many of them around I could swap in a used pack for him, or just buy an OEM one.
    Basically, we've decided against the Volt. Still up in the air on the C-Max, but I'm not sure how to feel about their long-term reliability since there just aren't that many around me, we'll have to test drive one to see how it is and go from there. He's also looking at an Infiniti Q50 (he's an old school Nissan guy), but I'm not sure if he'll want to give up the MPG of his current car (~25 w/ 87oct).
  19. douglasjre
    douglasjre Senior Member
    1,884
    653
    Orlando, FL
    What's a hangar queen
  20. ETC(SS)
    6,555
    Strictly speaking - an aircraft that is not flyable, usually due to multiple or very severe problems.
    In a fleet or squadron environment it's parked in the hanger - and often striped of useable parts to keep other birds flying until it is ultimtely scrapped or replaced.
    Sometimes?
    It's an accounting thing.
    If you have 8-24 hulls (truck, aircraft, ship) in a unit, group, squadron, etc...and one of them is constantly down for problem after problem then sometimes it's useful to 'keep it on the books' as a source for spare parts, maintenance training, etc.
    It's not meant as a complement.
    douglasjre likes this.
