Which PIAA wiper blade to reduce chatter?
Discussion in 'Prius v Accessories and Modifications' started by AJP, Dec 2, 2024.
  1. AJP
    AJP Member
    150
    Central Pennsylvania
    I've used Rain-X (1 time, not sure which model) and Bosch Icon (3 times). I've ALWAYS had windshield streak and chatter, even with a brand new windshield this year. No, the wipers aren't dirty, and no, there is nothing on the windshield. I've been reading rave reviews on PIAA wiper blades, but the PIAA site gives me options for the Super Silicone, Si-Tech, and Aero. Only the SS is a conventional blade, the others are beam.
    Which would you suggest to reduce the chatter and streaking?
  2. Tombukt2
    Tombukt2 Senior Member
    11,549
    2,026
    Durham NC
    I always have great luck with the Rain-X hybrid type with the exoskeletal pieces of plastic over the blade but essentially a beam type system works great usually don't have any clatter and any nonsense unless there's a lot of crud on the glass then I try and hose off the glass or do something else before I'm dealing with the wipers maybe spray the windshield something but if all else is not happening and then use the wipers I have Rain-X on my glass and all that so using my wipers is pretty rare event generally but I've had good luck with the Rain-X hybrids they're getting hard to find now Toyota blades are even a hybrid type very similar to the Rain-X with of course the Toyota logo on them. I couldn't tell you about the PIAA I've never personally tried them but I would imagine they should be relatively decent that company doesn't generally fool around with junk generally speaking.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,280
    5,651
    Texas Hill Country
    Oem aero blades and rubber. The blades are reusable with low cost oem inserts in the future.
    Toyota v insert part numbers:
    85214-47061
    85214-47051
    Rear
    85214-12310
    Blade, Front Wiper, LH 85222-47040
    Blade, Front Wiper, RH 85212-47060
    Blade Rear Wiper 85242-12090
    BiomedO1 likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    2,566
    1,377
    SacTown, Ca
    I used the OEM blades, but replaced the inserts with a commercial silicone, instead of the OEM rubber. The OEM rubber lasted less than 18 months, before separating at the pivot point. I'm 2+ years on the silicone. I do treat the glass with Rain-x annually.
  5. Mendel Leisk
    40,224
    Mostly parking outside?
  6. rjparker
    9,280
    5,651
    Texas Hill Country
    I find using the wipers to clean the windshield damages the rubber/silicon fairly quickly. I hand clean the windshield and major bugs most nights and live with dust and some bugs while driving. Saves windshield scratches as well.
  7. BiomedO1
    2,566
    1,377
    SacTown, Ca
    Yes, it's parked outside.
    Yes, NEVER clean your glass with the windshield wiper - that's a good way to scratch them up. When you clean your windshield, also wipe the grime off the blades. Road grime settles on the top of the wiping surface and will scratch your glass on the first wipe. I don't turn-on the wipers until there's a good bead of water on the glass.That ensure a good rinse of the blades and less chances of scratching your glass.
    Air_Boss likes this.
  8. AJP
    AJP Member
    150
    No, inside.
  9. ChaseE
    ChaseE Member
    66
    33
    29
    Oregon
    I've found that the AutoZone hybrid model works without chatter, but it did have some streaks until I thoroughly cleaned the windshield with #0000 steel wool and rain-x. Also don't forget to occasionally run a paper towel with rubbing alcohol on it across the blade to get any dirt and gunk off of it.
  10. BiomedO1
    2,566
    1,377
    SacTown, Ca
    FYI; If you use rubbing alcohol on rubber blades, it'll hasten it's demise. If you got silicone blades, it should be fine.
  11. Mendel Leisk
    40,224
    Prodigyplace likes this.
