Which Prius generation and year is best for camping?
Discussion in 'Newbie Forum' started by surfingisfun001, Dec 21, 2019.
  1. surfingisfun001
    surfingisfun001 New Member
    I am looking at getting a used Prius in which I could camp/live in. The 3 most important things for me:
    1) MPG
    2) Flat area to sleep
    3) Climate control
    Which generation, year, and model of Prius is best for camping/living in?
    I am open to Gen 2, 3, or 4. Are there certain years where the back seats fold down perfectly flat whereas others don't? Best years for MPG? Do all generations have climate control? I tend to like the look of the liftback (regular) more than the v (hatchback). I don't think I necessarily need the Plug In, though if it comes with, it can't hurt.
    Basically I'm just wondering if there is an obvious well known generation or year that Prius campers swear by, that is better than others.
    Thanks for your feedback!
    49,844
    welcome!
    gen 2 and 3 are flat, and have spare tires. gen 4 is not flat, so you have to build up part of it with foam or whatever. some gen4 have spare and some don't.
    each gen gets better mpg and of course, newer years/lower miles should be a little better depending on maintenance and condition.
    all gen's have climate control, but probably a bit more efficient with each gen, and newer batteries should run it longer with less engine cycling.
    i don't recall a concensus from campers, but i may be mistaken.
    both gen plug in's don't have a spare. the larger battery will give you a little more climate control the first segment before the engine starts cycling.
    if you looking at new, you can often buy a plug in for less than a non plug in due to rebates and credits.
    the roomiest prius is the v, but lower mpg's.
    alanclarkeau and surfingisfun001 like this.
  3. surfingisfun001
    Thanks for the response!
    so all the ones with spare tires are flat, and the ones without are not flat?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
  5. bisco
    49,844
    no, the gen2 and 3 have spares and are flat. the gen 4 comes with and without spare, depending on model, but neither is flat. the first plug in is flat with no spare, the second is not flat with no spare.
    surfingisfun001 likes this.
  6. PriusCamper
    PriusCamper Senior Member
    11,234
    4,588
    Pacific Northwest, USA
    Gen2 and Prius V allow you remove the center console between the front seats, which allow you to replace console with a pillow, then when it's time to sleep you slide both seats all the way forward, remove the headrests and recline the front seats all the way back flush with the back seat, then add lots of pillows and blankets to make everything flat. Alternatively, you could remove back seat entirely and replace with full size futon mattress which will lay out flat and turn the whole inside of the car into a bed.
  7. bisco
    49,844
    don't wait for a 2020, toyota has cancelled 'camping mode'. car shuts down after 20 minutes with no input
    alanclarkeau likes this.
  8. PriusCamper
    11,234
    4,588
    Also Gen2 Prius shuts down after an hour if you're listening to the radio in ACC mode....
  9. bisco
    49,844
    gen3 20 minutes, iirc
  10. surfingisfun001
    So no overnight climate control in gen 2?
  11. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Gen 4 with spare have a flat floor with the seats down. No spare means a 2" lip (trunk lower than seat), and Prime has a 4" lip (trunk higher than seat). I haven't seen the back of an e-AWD yet so don't know about those.
  12. bisco
    49,844
    is it flat with the folded front seats?
  13. alanclarkeau
    7,044
    7,585
    Best to go and have a look - this is mine, 2016 with a temporary spare:
    I figure if I were to camp, I'd possibly have a thicker mattress portion to the rear, and thinner over the back seat, and only a small pillow.
    Best to go and have a look at a few in car yards.
  14. Vman455
    534
    551
    The Middle
    Are Australian market cars different from North American then? Here's what American market cars look like with a spare (this is a Hong Kong car, but same as NA as far as the seats folding):
    Without spare:
    Prime:
    For comparison, Gen 3:
    Prius c:
    And Gen 2:
    That I do not know; I assume not.
  15. bisco
    49,844
    great pics, very helpful, thank you.
  16. PriusCamper
    11,234
    4,588
    Never once slept in that part of the car.... I camp comfortably in a Prius, which is why I'd never subject myself to that back part of the car, which is for cargo, not sleeping.
  17. surfingisfun001
    Where do you sleep?
  18. PriusCamper
    11,234
    4,588
    If car is in ready mode in Gen2 it stays on all night... If it's in ACC mode, it does not...
  19. bisco
    49,844
    don't let that post confuse you, it is not pertinent to the discussion
  20. surfingisfun001
    Some good feedback here. Thanks everyone.
    I think I am leaning towards gen 3, around 2012-2015, something with roughly 100k miles or less. Reasons being it's not too old to where it may have more problems, and not as expensive as the newer gen 4. A happy medium. Also I don't see anything wrong with those years and that generation in relation to my camping purposes, mpg, etc. The back looks a bit bigger in gen 3 than gen 2, and the seats look nice and flat.
    Sound like I'm on the right track? Am I missing anything? Any reason why gen 2 or 4 is better?
