Which public plugs work for 2020 Prime
Discussion in 'Prime Plug-in Charging' started by JeremyM09, Jun 30, 2019.
  1. JeremyM09
    JeremyM09 Junior Member
    Ohio
    2020 Prius Prime
    I traveling out of state tomorrow to pickup my new vehicle: a 2020 Prius Prime LE. I'm starting to look on PlugShare, etc. and see multiple different plugs.
    Which ones work with the Prime? I know that wall plug does and Testa doesn't. What about:
    J-1772
    CHAdeMO
    NEMA 14-50
    CCS/SAE
    Thanks!
  2. Tideland Prius
    16,616
    J1772 and wall (which uses the cable that comes with the car).
    If you have a portable 220/240V EVSE with the NEMA 14-50 plug, then you can use it. If not, stick with J1772 and wall outlets.
    TGrracie and Arctic_White like this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Any available 120VAC outlet using the EVSE that comes with the car. Motels, campgrounds, etc. frequently have these where you can use them.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    All J-1772 Plugs will charge, Level 2 plugs can charge as fast as 2 hours, Level 1 in 5.5 hours. J-1772 is on your cable Toyota supplied. No matter how many Amps the EVSE can provide, the Prime only draws 16 Amps
    CHAdeMO is a DC system, both the plugs and the voltage are incompatible.
    NEMA 14-50 is often used in RV/state parks, you can buy or build an adapter to the 5-15 on your existing cable to make it charge in 2.5 hours. (this adapter is non standard as it makes a 5-15 receptacle at 240 volts)
    220v NEMA 14-50P Plug to 3PIN 220v NEMA 5-15R RECEPTACLE POWER CORD ADAPTER | eBay
    CCS is a tossup, there are two style connectors, one allows J-1772, one does not. Assume it does not work in the US, and does in Europe.
    PlugShare - Find Electric Vehicle Charging Locations Near You
    Choose J-1772 (and NEMA 14-50 if you bought/made that adapter. Often stuck in RV parks)
    #4 JimboPalmer, Jun 30, 2019
  5. JeremyM09
    Ohio
    2020 Prius Prime
    Thank you!
  6. PrimerPrius
    PrimerPrius Junior Member
    Santa monica
    2019 Prius Prime
    Here’s the deal:
    It took me a long time to figure this out but perhaps this will be of help.
    I live near free public charging stations in Santa Monica. Every time I would take my empty battery Prime to get charged, it would take 4hrs and 50 mins to fully charge. I then realize I had the wrong setting on my car.
    The manual nor this community tell you this BUT if your car takes a long time to charge on a public charging station, please go to the car settings and change the charge settings from 8A to MAX!
    You can now charge at Level 2!
    salyavin and Justabrake like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I’ve seen that setting mentioned here before;).
    And I use it every day to charge at work(since I’m there for more than 8 hours, I 8A charge)(y).
    jerrymildred and PrimerPrius like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    @PrimerPrius, yes, it's been mentioned here a lot. But it's not bad to repeat it. (y)
    As for the manual, it's on page 123 in mine:
    TGrracie and Justabrake like this.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I thought the default is 12A on 120V, and 16A on 240V. I never checked or changed the setting on mine, but it dose complete charging by OEM EVSE at 120V in less than 6 hours.
    jerrymildred and TGrracie like this.
  10. jerrymildred
    11,517
    14,157
    Tampa, FL
    That's roughly what my meters read.
    Salamander_King likes this.
  11. PrimerPrius
    Santa monica
    2019 Prius Prime
    YES! But it doesn’t do a good job explaining:
    “Level 1 / 120V (Slow charging) select 8A”
    “Level 2 / 240V (fast charging) select “MAX”
    It’s confusing and unclear.
  12. jerrymildred
    11,517
    14,157
    Tampa, FL
    I can't find your quotes in my manual. Where did you find them? My manual doesn't say anything about charging voltage in the section about selecting charging current.; just charging current. Heat is a function of current, not voltage. The ability to reduce charging current is there solely for those situations where there are other loads on the same circuit breaker and they cause the breaker to trip when you plug in the car.
    It's perfectly clear. Use the lower amperage if the breaker trips when using max amperage. Done. That's it. Voltage is no more of a factor in this than the color of your shoes.
    Salamander_King and Raytheeagle like this.
