Which side does the gas fill up go ??
Discussion in 'Gen 2 Prius Main Forum' started by wtfjr, Nov 18, 2007.
  1. wtfjr
    wtfjr New Member
    38
    I recently read an email where in it said that, when sitting in any car, you can always tell which side of the car to fill with fuel by looking at the gas pump symbol on the dash & the side of the pump that the hose is shown will be the side to fill from.
    Not so on the Prius, which I just discovered. The hose is on the right side of the pump !
    But, there is an arrow to the left of the dash gas pump which does point to the left, the side to fill from.
    Is this really old news ? If so, please no flaming. If not - HURRAH !!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Never heard the hose part before...I've always just looked for the arrow.
  3. GeekEV
    GeekEV Member
    417
    NorCal, USA
    Personally, I just look for the gas cap door. :p
  4. daniel
    14,487
    1,518
    Spokane, WA
    <div class='quotetop'>QUOTE(Mr. Zorg @ Nov 18 2007, 08:15 PM) [snapback]541414[/snapback]</div>
    Yep. Me too!
  5. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I've never heard the gas pump symbol story. All the symbols I've seen have the hose on the right. All the cars I've had that have an indication used an arrow.
  6. Sitting Duc
    Sitting Duc Feathered Member
    61
    Hamilton, New Zealand
    I've heard two variants on the hose theory; the first being the side of the hose = the side of the car, as the OP suggested; and the second being if the fuel gauge is left of the speedo, then the cap is on the left of the car, and right for right.
    I've also found that this theory does not apply consistently, so you have to stop and look for the flap anyway.
    At least my prius has an arrow :)
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I drive a few different car in my work. I pull the release then look for the flap in the side mirrors.
  8. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I used to travel for business extensively and always looked to the gas gauge to determine what side the gas lid was on. Just about any business traveler will tell you that when you are on the way to the airport on a Friday afternoon, you do not want to have to jockey the car around the gas station trying to top off the tank.
    With what I consider very few exceptions, I believe that it is pretty consistent that the gas symbol is on the same side of the gauge as the lid is on the car. For those - such as the Prius - where it is not, I have seen arrows pointing.
    Where I did find considerable inconsistency was in the functionality of wipers, headlights, and other assorted steering wheel stalk functions.
  9. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    honestly I dont remember, because I dont even remember the last time I filled up! Prius FTW!
  10. Sarge
    Sarge Senior Member
    1,304
    761
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Here's a somewhat-related factoid some may find interesting...
    The exhaust tailpipe is (AFAIK) always on the opposite side of the car in relation to the fuel door, except of course when said car has duel exhaust pipes. ;) Presumably, I would imagine this is done to distance a source of heat from flammable fumes... :eek:
    Check it out... B)
  11. SaintStephen
    SaintStephen New Member
    32
    That was one of the tappet brother's quiz's. Funny.
    ss
  12. daniel
    14,487
    1,518
    Spokane, WA
    I had never noticed the little gas pump icon before. Today, after reading this thread, I looked for it. The pump handle on the icon is opposite the fuel filler. The little arrow points towards the filler.
    But whenever I rent a car I just look to see which side the filler door is on.
