Which used Prius?
Discussion in 'Newbie Forum' started by james909, Apr 25, 2025.
  1. james909
    james909 Junior Member
    84
    16
    Leeds, U.K
    My gen 2 is 20 years old and 140,000 miles driven. I bought it 10 years ago on 90,000 miles. Looking to do something similar again. What should I buy?
  2. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    We don't know how thick your wallet is!
    You can buy a new 2025 Prius and drive it for another 20 years.
    You can buy a used 2016 and drive it for 10 years.
  3. james909
    84
    16
    Leeds, U.K
    I guess I'm debating between a 2015 Gen 3, 2016 Gen 4 or a 2009 Gen 2. All with around 90,000 miles on the clock.
  4. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Tough choice.
    Gen2 is reliable as a tank, but old. It may not last another 20 years.
    Gen3 is good, but has its own problem areas (cylinder head gasket, water pump, EGR,
    Gen4 is possible, but it is too low for me. Maybe this is your option.
  5. ColoradoCrow
    ColoradoCrow Senior Member
    1,090
    448
    Leawood, KS
    I
    I understand the sweet spot is a 2019 L ECO...still comes with a spare tire and (normal sized flaccid) Screen.
    Some heater exchange bypass reports... I'd research that a bit.
  6. bisco
    51,011
    2015 is the best gen 3. there are issues that might crop up: head gasket, brake actuator, hybrid battery.
    the egr circuit should be cleaned evry 50k or so, and an oil catch can added.
    2016 had many improvements, egr being a major one.
    only defect is the exhaust gas heat exchanger which has leaked out the engine coolant and caused a blown head gasket.
    we don't know how many are bad, not everyone has had the problem, but toyota did update the exhaust in 2018 i believe,
    2009 is a tank as mentioned above.
    if you can trust the mileage and it doesn't burn oil, it might be a good choice, but plan on a replacement hybrid battery and possibly the brake actuator.
    you did well with the 05, but don't count on that happening again. if it does, take it as a pleasant surprise.
    all the best!
