Which water pump? AISIN WPT 190 or WPT 190-A
Discussion in 'Gen 3 Prius Main Forum' started by ToyotaCoyotta, May 21, 2025.
  1. ToyotaCoyotta
    ToyotaCoyotta New Member
    26
    Lithuania
    Hello,
    Planning to change the water pump to avoid head gasket issues
    How do I know which one I can pick to be safe?
    AISIN WPT 190 is 150+
    while
    AISIN WPT 190-A is 250$+
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    For piece of mind I bought the real TOYOTA one /
    ASRDogman and Brian1954 like this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,135
    2,144
    Durham NC
    I've just replaced the impeller in the two that I had that are now blown up and gone but the pumps are still here laying on the ground not sure what the a is about I don't know if I really care. It's a MAG drive type pump so unless something burns up in the housing usually all that's happened is the skin is peeling off the impeller you get a new impeller strip that one whatever and then it'll spin again or a new one will spin in its place the housing usually doesn't get messed up it's the impeller so replace of it what you'd like I guess we're just trying to keep the water moving that's all not too much heavy science about it.
  4. Mendel Leisk
    40,534
    ToyotaCoyotta likes this.
  5. ToyotaCoyotta
    26
    Lithuania
    Have you bought this Pump before ? can’t find any reviews about this specific item from this seller
  6. Mendel Leisk
    40,534
    No, but it’s the option I’ll likely go with, once we’re “close” to 100k miles. Currently at 104k kms, may never get there.
