Which way is north
Discussion in 'Gen 3 Prius Audio and Electronics' started by atlantic442, Feb 7, 2015.
  1. atlantic442
    atlantic442 Junior Member
    Oregon
    I just bought a 2015 Mod III, which has navigation. Is there anyway to get the GPS to show which way is north. On the 2007 I traded in the north indicator was in the upper left corner.
    The indication on the 2015 doesn't indicate which way is north. The 2007 was a user friendly system, and much faster
    Hans
  2. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Hans,
    The top left triangle button on the nav screen when pressed will then give you 3 options.
    3D Heading
    2D Heading
    And
    2D NORTH
    Hope this helps.
  3. atlantic442
    Oregon
    I have used all three choices, and have found the GPS does not know which way is north. In my Prius, the North indicator is off 90-180 degrees. Is there anyway to calibrate the GPS, or is it a dealer problem
