Which wire on 2010 cigarette lighter is hot?
Discussion in 'Prius v Accessories and Modifications' started by Bigham, Nov 2, 2013.
  1. Bigham
    Bigham Junior Member
    Is it the white / black wire? Going to add a fuse for constant power to add three way cigarette outlet adapter for cell phone and satellite radio. Which wire do I splice in to on the back of the lighter plug?
  2. Mendel Leisk
    38,653
    You definitely should get a multi-meter.
    If your intention's to have constant 12 volt power available, keep in mind: power is cut from the 12 volt sockets when the car's off for a reason: the 12 volt has a limited capacity.
  3. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    Multimeters can be had for $1, so I second the advice above.
    That said, ground is the wire that goes to the outside of the lighter casing, and + is the wire leading into the center of the lighter plug.
