While driving; fast beeps for 2-5 secs and solid dash light comes on.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mo.C, Jul 12, 2014.
  1. Mo.C
    Mo.C New Member
    A 2010 Prius III:
    Its been a few days now that its doing this.
    While i'm driving, the car would start to beep fast (3-4 beeps per sec), the brake and steering wheel stops working, its very stiff and brake pedal is hard! Along with that, there's 4 lights came on the dash; traction control, abs, brake and tire pressure. All this happens when the car starts to beep, and the beep last anywhere from 2-5 second, constantly!
    I checked everything and its normal, gas half tank, keyless key is in my pocket, all doors closed, brake pads looks good, tires are good. I've had this car for 4 years, its at 45k miles.
    I do not know what the problem could be, please help!
    49,504
    welcome to priuschat! you need to pull the codes for us. either the dealer, or possibly an auto zone or some other place like that. all the best!(y)
  3. JC91006
    16,482
    8,400
    I would suspect the fast beeping to be a warning to alert you the car is malfunctioning. Have you done the recalls on the car? 2010 has 2 recalls, brake booster and inverter reprogramming. Both of those recalled items can cause what you are experiencing. I suggest you go to the Dealer ASAP to get this done......maybe even have your car towed there (dealer should cover the cost of tow if it's a recalled item failure) because it sounds like it's pretty dangerous to drive.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'm going to bypass any speculation and advice outside of "Get to A Dealership".
    I'd be much, much more concerned about "The brake and steering wheel stops working, its very stiff and brake pedal is hard!" than the beeping sound. It's all probably related, but the scenario you are describing sounds very dangerous to me.
    Whatever it is, you need to get it fixed ASAP.
    Good Luck.
    Mendel Leisk and xpcman like this.
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! go to dealer Now!!!
  6. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    Like this?
    Happened to me once.... I was able to get it to the closest dealer, who reset the codes and it never happened again, and I drove the car for another 2-1/2 years, maybe 50,000 miles. Their take was due to the bad traffic I was in, I did a combination of brake/gas/brake/gas that flipped it out. I thought it may have been that I had just filled the tank from near empty, but that wouldn't matter in your case since you have 1/2 tank.
    Turning the car on and off did nothing.
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    How's your 12 volt battery? Has it been replaced?
  8. bisco
    49,504
    some have thought the hatch was closed, but the switch needs to be adjustment.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Lose steering and brakes stop working? What?
    Been a few day's the car has been doing this.
    Your driving a car for days that's losing steering?
  10. bisco
    49,504
    have you checked the health of the 12volt? notorious on the '10's.
  11. Robertto09
    Robertto09 Junior Member
    51
    Costa Rica
    How you fix the problem? I get it right now!!
  12. bisco
    49,504
    if it is the 12v, charge it and keep an eye on it. if it won't hold 12.5 or better, replace it
