While on a 500 mile drive, the battery bars are GREEN NOT BLUE, what is going on??
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 17, 2018.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    When the top 2 bars are charged the color changes from blue to green. Just like when you are at the bottom 2 bars it’s purple. You probably have the battery almost topped off.
  3. Skibob
    2,912
    1,505
    Northern California
    I was going down a big hill the other day and when the battery was fully topped off the arrows turned off. Didn’t show the battery charging anymore.
  4. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Was the heater on?
  5. bisco
    51,968
    could be the hybrid battery going south if
  6. Fredsimm
    188
    117
    Tupelo MS
    That's what you told me last year and it was heater usage. A member here said when temps drop and we run our heaters, the battery stays in the green a lot. It was true.
  7. bisco
    51,968
  8. bisco
    51,968
    what is the connection between the battery and the heater?
  9. Fredsimm
    188
    117
    Tupelo MS
    Not sure, but I see more green in the winter. Here's a pic of the post from last year.
  10. bisco
    51,968
    makes some sense in ms i guess
    in real winter, the battery is taxed more heavily
  11. Skibob
    2,912
    1,505
    Northern California
    You see more green because the battery temp is lower and the AC compressor has to run less.
  12. nolotank
    nolotank Junior Member
    33
    23
    United States
    More green in the winter because running the heater requires running the engine more often (heat source), and the engine (when running for no reason except to provide heat) charges the traction battery.
    OP, as I wrote in your nearly identical questions thread several days ago:
    Basically, the color of the bars only accentuates their presence.
    Purple = "low" charge, Blue = "normal" charge, Green = "full" charge.
    Seven to eight bars = Green
    Three to six bars = Blue
    One(!) to two bars = Purple
    Just serves as an extra visual indicator of the current state of charge. Contains same information as the number of bars, just a simpler format.
    In summary, you have nothing to worry about. The computer is managing the battery level normally, and the color is simply an indication of charge level.
    srellim234 likes this.
