Whine and buzz under the hood while in Ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by richard schumacher, Jan 31, 2009.
  1. richard schumacher
    7,663
    1,038
    United States
    Before today I'd never listened under the hood with the car Ready. There's a distinct whine and buzz apparently coming from the inverter, audible only when the engine is not running. Is This Normal? All the coolant tanks are full.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The inverter does whine.
    Tom
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    You will hear the inverter and also the coolant pump
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The coolant pump is very quiet, and the inverter doesn't make
    a whole lot of noise when the car isn't moving.
    You're most likely hearing the throttle motor on the front of
    the engine.
    _H*
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    My 07's Inverter is real loud just sitting in Ready first thing in the morning. Really loud.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    I had a whine under the bonnet until I let my wife ride in the cabin with me, now I have a a whine inside the car.
  7. edthefox5
    10,096
    4,805
    Clearwater, Florida
    bwahahahahahah........nice.......
  8. patsparks
    10,664
    567
    It's a hastle that I can't tow a trailer with my Prius or I could fix the whine.
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    H
    Oddly enough, the electric throttle on my Prius is *very* quiet
    However, the electric throttle on my FJ does make a loud whine. I found this out last fall when I decided to clean the throttle body and MAF. I had a neighbor kid keep the gas pedal floored while I sprayed the gunk out of the TB, and it really does make a lot of racket, no matter at full throttle or idle setting
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    :doh:
    I sure hope you're not suggesting she is
    :ballchain:
    Or you'll be sleeping on the couch for the rest of your natural life
  11. richard schumacher
    7,663
    1,038
    United States
    What is the throttle motor doing when the engine is not running?
  12. jayman
    13,439
    640
    Winnipeg Manitoba
    With my FJ, engine off and key on, the throttle positioner will make a loud whine whether the gas pedal is released or floored. The Prius throttle positioner is almost silent, at least mine is
  13. Bob64
    1,540
    92
    Virginia
    the buzz sound is likely the brake accumulator pump.
  14. jayman
    13,439
    640
    Winnipeg Manitoba
    The electric brake boost pump does not run constantly. When you first press the brake pedal, it will make what I consider a "rattle" sound. My FJ also has electric assist brakes, and they make a similar noise
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    By putting her in the trailer? :rolleyes:
    I find wearing headphones takes care of all the annoying noises, in the car and the house. :)
  16. patsparks
    10,664
    567
    Yes, exactly.
    I hate how headphones make my ears sweat.
  17. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I don't like that, either, even though we've got nothing like your heat. I quite like the earbuds I have now - they're comfortable, don't fall out easily like the iPod style tend to, and feature very good sound for the price.
  18. patsparks
    10,664
    567
    Yes, I like the in ear buds with the soft bit around them that seal in your ear, I have a set for traveling.
  19. jayman
    13,439
    640
    Winnipeg Manitoba
    :doh:
    I hope she never looks over your shoulder as you type
  20. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Good one Hobbitt! I was under the hood this weekend listening to all the noises and you are absolutely correct it is not my Inverter it is the throttle motor squealing real loud. I always thought that was my Inverter making that squealing. In fact the Inverter is very quiet as you stated. Thank you I stand corrected.
