Whirring electrical sound (at startup) getting frequent
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alokeprasad, Apr 4, 2016.
  1. alokeprasad
    alokeprasad Member
    162
    Ohio
    On my 2010 Prius (~75,000 miles): The whirring electric motor sound that one hears when just entering the vehicle (even before starting the vehicle) seems to be getting more frequent (and maybe louder).
    I used to notice it only when getting in the car and before or just after pushing in the start button. But now I notice it driving around the neighborhood, even at moderate speeds.
    Is this a sign of some impending failure?
    Thanks.
    Aloke
    52,393
    that's your brake accumulator tank. it would be unusual to fail this early, but certainly possible. maybe your hearing has improved?:)
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It's the brake pressure pump bringing the brake system up to pressure (getting the car ready for you to drive). It's possible over time it will run longer to begin with. The brake system always leaks some fluid past the seals (usually in the master cylinder) and that should increase with age and use. I don't think it has anything to do with "impending failure". Pearl S has always run much more than Pearl ever did. The Prius doesn't use vacuum for brake boost because the engine can shut off at any time, so instead it uses an electric brake fluid pump and an accumulator reservoir.
  4. Former Member 68813
    3,524
    983
    US
    Well, maybe it's nothing, but I would start looking for cheap used part on eBay. These things are known to fail and are expensive at a dealer.
  5. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Did you have the brake accumulator recall done?
