Whirring noise after I shut it off and remove the key
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by impreza, Apr 4, 2004.
  1. impreza
    impreza New Member
    33
    Lincoln, RI
    After I shut the car off I hear a quiet noise. It lasts about 30 seconds and seems to be coming from the engine. What is it?
  2. Lectricar
    Lectricar New Member
    98
    Glenmoore, Pennsylvania
    Coolant being sucked into a thermos in the engine...it assures a warmed up car
  3. impreza
    impreza New Member
    33
    Lincoln, RI
    WOW! I heard something about water being kept "HOT" for the next startup and wondered how that worked.
    Those guys thnk of everything!
    How long does that water stay hot?
  4. starla30
    starla30 New Member
    160
    Northampton MA, USA
    "To optimize engine and emissions performance, the new Prius uses an electric water pump and insulated hot water storage thermos ('HC absorber'). The intent is to ensure the engine is warm before the hybrid demands power from it. The claim is that the water storage system can maintain the water temperature above 85 degrees for 3 days."
  5. impreza
    impreza New Member
    33
    Lincoln, RI
    Thanks for the info.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Actually the HC absorber was used on the '01-'03 Prius, and was a special catylitic converter which absorbed HydroCarbons (HC's) until the cat was warmed, at which point they were burned off. This was later applied to the '04 Camry PZEV.
    The thermos in the '04 heats the engine so that it doesn't generate as many unburned HC's while it's below normal operating temp.
    I would have liked to have seen both in the '04, but alas.
    They say that the Thermos can keep the coolant at near boiling overnight, and quite warm for several days.
    -Rick
  7. jeffrey
    jeffrey New Member
    94
    I get the same noise, but I've noticed that after a few more minutes (perhaps 3 or 4) I often hear another rumble/slight grinding noise coming from somewhere under the passenger compartment. Something to do with the drive battery I suppose?
    I was looking in the manual last eve to see if I could find it, but have not as yet. Anyone know?
  8. HTMLSpinnr
    5,339
    917
    251
    Brake pressure pump.
    I hate to say this, but these topics have all been covered before - search through the forums and you'll find that we've already gone into detail on this.
    -Rick
