Whirring Sound When Opening Door
Discussion in 'Gen 3 Prius Technical Discussion' started by kenopa, Mar 29, 2010.
  1. kenopa
    kenopa Junior Member
    57
    Indiana
    Every time I open the drivers door, a whirring sound starts from under the hood, then it gradually slows and stops. Maybe from the inverter area. What is this and is it normal operation? Or is this the Prius saying hello?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    That's the brake boost pump building up pressure and it is normal... After it does this if you sit around before taking off the pressure drops a bit and the brakes can feel a little grabby until the pressure rebuilds. Not a big thing though...
  3. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Yep normal, It's the brakes.
  4. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    it could also be a wife or girlfriend sitting in the passenger seat
  5. kenopa
    57
    Indiana
    Nah. Different sound. Goes like "Nag,Nag,Nag when I open the drivers door, and it never goes away.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    It *is* the car saying hello, and reassuring you that its braking
    system will work just fine despite everything you've heard on
    the news.
    _H*
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I thought it was the photon torpedoes energizing.
  8. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    Heard it last night, too :)
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    So what is the difference between this sound and the coolant bladder or coolant exchange tank or whatever it is? I had read on here previously that is what the sound was...
  10. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    There is no more coolant thermos in the 3rd Gen Prius. It was in some way replaced by a coolant heat exchanger on the exhaust system.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    ah... My lowly Gen II makes a different whirry sound then!
    So I wonder if I make both sounds, or if Toyota decided since they got rid of the source of the sound on the Gen III, they would add it back in with a new source, the brakes! :)
  12. Radiant
    Radiant New Member
    148
    17
    NE
    If you like the whiring sound: try staying in your car for a few minutes or returning to the garage after turning the car off. You practically get an orchestra performance.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Gen II also has the electric brake accumulator pump, although it doesn't run when you open the driver's door. You can hear it about every third time or so when you press the brakes.
    Tom
  14. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    I noticed this for the first time a few days ago. There was such a chorus of sounds I started to refasten my seat belt just in case! The Prius really is from outer space! :)
