whistle every 30 seconds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gn7, Jan 10, 2012.
  1. gn7
    gn7 New Member
    israel
    I encountered a strange thing today:
    Something in the car is whistling every ~30 seconds.
    When the key is in the switch - I can't see any unknown light,
    but when I power off the car - a red light ( a car with a key inside it) flickers... the whistling continue although the car is powered off...
    Any ideas?
    Thanks.
  2. richard schumacher
    7,663
    1,038
    United States
    The flashing red car-key light (the immobilizer system indicator) is normal and has always been there, or should have been. The whistling, I have no clue.
    49,500
    :welcome: an alarm perhaps? did you just buy the car?
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Whistling? Explain more. Do you mean whistle as in a beep or buzzer or whistle as in wind blowing against something?
    What warning lights are actually on? What is the mileage of the car and what is its age.
    The more info you provide the more we can try to assist. :)
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Usually these sorts of sounds turn out to come from some device left in the car, such as a cell phone.
    Tom
  6. bisco
    49,500
    or a whistle, did you give a referee a ride home?
  7. qbee42
    18,058
    3,074
    Northern Michigan
    The OP said "whistle", and he hasn't been back in a week. I'm guessing it was a train. :eek:
    Tom
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    ...the infamous "light at the end of the tunnel."
    <Loud crashing sounds>
    :p
  9. bisco
    49,500
  10. Goughy
    Goughy Junior Member
    29
    Southern California
    I also have this beeping when the car is parked and off. The beep is at approximately 30-second intervals.
    No warning lights (other than the immobilizer indicator).
    One more weirdness - if I am sitting in the car, front or back seat, with or without the fob, the beeping stops.
    The Prius is a 2005 with about 108,000 miles.
    Any suggestions as to the cause?
    #10 Goughy, Sep 23, 2017
  11. bisco
    49,500
    unusual, try disconnecting the battery for a few minutes.
    any aftermarket parts, accessories or alarms?
  12. Goughy
    29
    Southern California
    Yes - my idea was also to disconnect the battery. Unfortunately, the negative terminal has quite a bit of buildup and I haven't managed to free it up yet.
    No aftermarket parts - we've had the car from new.
    Thanks for your reply.
  13. bisco
    49,500
    are you using vinegar to soak it?
  14. Goughy
    29
    Southern California
    Oh dear! Red-face time :oops:
    I was too quick to blame the Prius. Turns out that the pitch of the garage door opener backup battery warning is almost identical to the Prius.
    Why I couldn't hear it in the car is another question - I blame my aged hearing.
    Thanks for your help, bisco.
  15. bisco
    49,500
  16. bisco
    49,500
    i would still take care of those corroded battery connections.(y)
