Whistling sound comes from engine
Discussion in 'Gen 3 Prius Technical Discussion' started by Princedunet, Jan 27, 2018.
  1. Princedunet
    Princedunet Junior Member
    46
    morocco
    2012 Aqua
    Hello everybody, I starter to hear a whistling sound coming from the engine in my Prius 2012 with about 150000km, it sounds to be electrical then a mechanical sound, it very annoying that hurt the ears. I tryed something, While I’m driving I switched to (N) Neutral and this sound gone, when I switched back to D (Drive) the sound back. Someone told me that the inverter is the responsable of this sound! Anyone can help me to solve this probleme via the sound is very annoying.
    Thanks in advance.
  2. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    Howdy Prince. Is it possible to record the sound with your cell phone? I'm very curious. Although I'm sure someone will have an answer for you from experience.
    Princedunet likes this.
  3. Princedunet
    46
    morocco
    2012 Aqua
    Im at home now, I will tomorow, but it is like an electrical whistling , it’s very annoying and it cuts the ears. hope is not the inverter
    #3 Princedunet, Jan 27, 2018
  4. Princedunet
    46
    morocco
    2012 Aqua
    I’ve got an idea and I would share it with you. I’ve baught my car used with about 115.000km, and I never changed the inverter coolant, I was reading about that and I found that I should replace the coolant every 120.000 150.000 km, and mine is about 150.000. Can this cause a wrong function of the inverter and make this sound?
  5. bisco
    51,154
    is inverter whistling a bad thing?
  6. padroo
    padroo Senior Member
    2,763
    2,251
    Just a guess the inverter pump squealing.
  7. Princedunet
    46
    morocco
    2012 Aqua
    So you thing this whistling is normal
  8. Princedunet
    46
    morocco
    2012 Aqua
    Don’t know bro, hope is just the pump and not the hole inverter
  9. bisco
    51,154
    mine whistles in the cold weather, i suppose that isn't an issue in morocco?
  10. Princedunet
    46
    morocco
    2012 Aqua
    The weather here is not so cold , do you think the Weather is the prob?
  11. bisco
    51,154
    i think mine has whistled at 8, but i might have a problem i don't know about. my 2012 has 90,000 km.
  12. Princedunet
    46
    morocco
    2012 Aqua
    So your case is just in winter?
  13. Princedunet
    46
    morocco
    2012 Aqua
    Hey guys , I found a video in YouTube, it explains why inverters make such sounds, not the Prius inverter but the sound I hear from my car is same .
  14. padroo
    2,763
    2,251
    I didn't hear any of them, my hearing is bad though.
    Lightning Racer likes this.
  15. bisco
    51,154
    yes. according to that video, sounds like you're good. nice find.
  16. Princedunet
    46
    morocco
    2012 Aqua
    So that sound is normal or it’s an issue on the inverter, sorry for Bein late in answear
  17. bisco
    51,154
    sounds normal to me, they aren't all the same for some reason, our hycam whines louder than our prius.
  18. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    OP states the whistle stops when switching to neutral. Not sure about this, but wouldn't the inverter continue to emit the sound as long as the vehicle is made READY? If so, something in the PSD then?
  19. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Depends on how loud it is. I have a mid fresh cycle 2012 and it does make a whistling sound when lightly press and hold accelerator down while car is EV and not in EV driving mode. When I lift my feet off the accelerator, sound goes away. I can hear the sound but it doesn't annoy me, the sound is magnifited when you drive on narrow road with sidewalks. You can hear it very well also in a pa/rking ga/rage like the airport or downtwon. It doesn't annoy me because I grew up with old computer with fans running at highest RPM. Computer nerds now and days complain about that haha, "the fans a/re soo loud" no shit your computer temp remains cool. Now I'm just venting r/andom thoughts.
  20. Princedunet
    46
    morocco
    2012 Aqua
    Yes the sound stops when switching to N and it starts when I accelerate more then 50km/h, But the sound is more electrical then mechanical that why I don’t think is the PSD but I’m not sure about. I recently changed the transmission fluid.
    Thank bro
