White Body color different than bumpers
Discussion in 'Gen 3 Prius Audio and Electronics' started by stanleydan, Dec 18, 2009.
  1. stanleydan
    stanleydan New Member
    Shawnee, Ks
    Just purchased 2010 Prius (Blizzard) and when we got it home in the sun the next day we noticed a real difference between the paint color on the bumpers vs the body - a little greyer-
    I thought the paint was supposed to look exactly the same on both-even though one is metal the other plastic. Anyone else see this?
  2. ajc
    ajc Member
    340
    38
    pa
    I have the white and I did not see any difference but I will take a look.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Mine are a perfect match. If it is real noticable, I would have the dealer take a look and press them to have it fixed.
    Also look in the paint for any rust colored specks. I had a bad case of "rail rust" or "industrial rust". They will be embeded into the paint.
    Palm Beach Diva and stanleydan like this.
  4. R2Pre2
    R2Pre2 Feel the Force!
    111
    24
    SF Bay Area
    2018 Prius Prime
    There actually is a slight difference in paint color in the Blizzard Pearl between the body and front/rear bumpers. Part of this the material difference of the body and the bumpers. It should not be too noticeable, but is definitely there depending on the lighting conditions.
    R2Pre2 is Blizzard Pearl and have personally seen this very slight difference.
  5. Tideland Prius
    16,155
    Yup. Same effect on our Titanium Metallic (aka silver) Camry and our Tideland Pearl Prius. The Blue Ribbon is probably the one that's hardest to see but the difference is still there. I'd say the Camry's colour difference was the most obvious.
  6. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Dan,
    I have the same thing with mine. Although, it depends on what viewing angle it's seen under.
    The reason is partially due to materials, but due more to what's called "flop" -- the alignment of the particles which make up the pearl effect itself. The bumpers & door handles (you'll notice the same color differential in the door handles as well) are painted off the vehicle. Subsequently, the "flop", which creates the pearl effect, will give the illusion the colors are mis-matched.
    I have noted, at least on mine, that as I walk around the car, the parts go from not matching to matching, depending on the angle at which they are viewed. It's an unfortunate "artifact" of the pearl process.
    2 people like this.
  7. snowykim
    snowykim New Member
    53
    This should be same regardless of color or vehicle. You cannot bake plastic or poly urethane bumper to the same heat as your metal body in factory painting process.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Same issue with metallic colors, although not as pronounced as pearl finish. And even non-metallic/pearl colors can have a color match issue, since often the bumpers and other small parts are painted on a different line than the main body parts.
  9. trashcan
    trashcan Junior Member
    26
    San Jose
    The bumper uses "flex" type of paint and has few more layers than the paint on the metal so there's a little noticiable difference.
  10. Frankblack0503
    Frankblack0503 New Member
    64
    Belgium
    My doorhandles on my blizzard look darker tinted, depends on the light conditions...
