White Staining on Door/Window Trim
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jamesmaya, Jan 19, 2014.
  1. jamesmaya
    jamesmaya Junior Member
    28
    I
    Hi. In Nov. 2013 I purchased a used 2010. It came with some white staining on the otherwise black plastic strip of trim on the driver's door/window, as shown in the photo below. Does anyone else have this problem, know what the staining might be, and how to get rid of it? Could it be "wear" from the previous driver using their hands on this location to close the door when they exit the car? Thanks!
  2. JC91006
    16,673
    8,518
    I have the same type of stains on the inside of my car. Mine is from my kids wiping sun block everywhere. I haven't found anything to get rid of it, I was afraid to use any harsh cleaners that can strip the black off the interior.
    jamesmaya likes this.
  3. jamesmaya
    28
    I
    Thanks for the reply. Sunblock. Interesting. I'm in L.A. too. Could be that the previous owner used sunblock a lot.
  4. JC91006
    16,673
    8,518
    If the previous owner lived in Santa Monica or close to the beach areas, chances are it's sunblock
  5. peterjmc
    917
    189
    Clarksburg, MD
    Could be wear from hands... If they were heavy from calluses
    Nexus 5
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I have also had this problem with sunblock.
  7. jamesmaya
    28
    I
    Thanks. Have you tried anything to remove the stains?
  8. jamesmaya
    28
    I
    Thanks
  9. El Dobro
    El Dobro A Member
    7,075
    3,258
    Try this.
  10. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Sunblock, hand lotions, and oils from skin will cause staining on black/dark surfaces in and out of the car. The best way to prevent it is to be consistent with cleaning the affected surfaces when you wash the car.
  11. jamesmaya
    28
    I
    I'll give it a shot. Thanks!
