Who did over-inflated my tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cipsaz187, Feb 25, 2015.
  1. cipsaz187
    cipsaz187 Member
    147
    42
    Just checked the pressure and the front tires were 55 PSI and rears 50. Just could not believe it. I thought it's the gauge, but checked on other car and seemed fine. I keep it at 39/37, I've no idea how this happened. I could have not done this. Any ideas?
  2. caedward
    caedward Junior Member
    Fort Worth, Texas
    Who serviced your car last?
  3. cipsaz187
    cipsaz187 Member
    147
    42
    It hasn't seen any service since I purchased the car. I do the oil changes.
    Maybe the weather? It was -10F here in Chicago.. I've no idea.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Cold weather will make them drop, hot weather will raise them so I doubt it is the weather at -10F if you kept em' at 39/37. To go up that much in the winter seems air had to be added somehow.
    Was it in for anything, anywhere? Recall, inspection?
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Can't be the weather. For pressure changes like that the temperature would have to change >130F. Did you go to Hell and back?
  6. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    You have a 2012 that hasn't seen service and you just now checked your tire pressure? :rolleyes:
  7. cipsaz187
    cipsaz187 Member
    147
    42
    It hasn't seen service since I purchased the car which was a year ago.
    And I do check the pressure regularly.
  8. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    You keep saying it was not in for service but I asked was it in for anything else, possibly an inspection or a recall, or, anything? There is no way it went up like that without human intervention quite honestly or gauges were off along the line somewhere.
  9. frodoz737
    4,297
    2,348
    33
    Well then based "only" on the info you gave, the possibilities I see is either different gauges have been used over this time or someone did a drive-by to fill your tires.
  10. cipsaz187
    cipsaz187 Member
    147
    42
    Costco did the inspection on tires.
    Either I did it or someone else.
  11. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I'm pretty sure it wasn't Tom Brady or Bill Belichick who over-inflated your tires .....now if they were under-inflated by a couple of pounds after a recent drive through the Boston area we may be onto something :)
    Sergiospl, Boston Jim, bisco and 2 others like this.
  12. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    So stop holding out.... what were your MPG's with that high of tire pressures?? Us hypermilers want to know!! :whistle:
  13. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    Gosh I hope this is not an emerging trend with the punk kids! Randomly pumping up Prius tires.
    And to think back in the day the prank was to deflate tires.
    Boy how the times have changed!
    Sergiospl and PriusGuy32 like this.
  14. fuzzy1
    10,164
    Was the outside temperature significantly higher this time than when you previously topped off the tires? Was that -10F reading from this time, or from the previous time?
    Were the tires highway-warmed this time, vs. morning cold last time?
  15. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Wait......what ??
    I thought you first said that YOU found them over-inflated.
    Did Costco find the over-inflated condition and report it to you........or did you find it that way AFTER they did their "inspection" ??
    It is always possible that the report from the shop (any shop) might not be 100% true.
  16. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Maybe the gauge malfunctioned because of that temperature? (If it's a digital one ... )
  17. Blizzard_Persona
    1,787
    944
    Pa.
    2023 Prius Prime
    XSE
    I keep two gauges in my car, a digital and a good old style one (the face looks like a speedometer, not the one that pops out the bottom). I use both to check the tires as I fill them and they both seem to be spot on.
    Btw, how often is everyone checking thier tire pressures here?
  18. ETC(SS)
    6,544
    I'm sure you do. ;)
    It's quite obvious that either people are hauling air flasks around the streets of Chicago in the dark of night and randomly putting about 10-psi into unsuspecting people's tires while they sleep, or your spouse just took out a very large life insurance policy on you.
    You'd better check the brake lines too.
    Me?
    I tend to discount the "Air Flask" theory. It's been too cold up there for that kind of foolishness.
    The PNOK (Primary Next Of Kin) theory is also kinda out there, so I'm going to guess that it's an instrumentation or a maintenance error.
    Set the tires to whatever you actually want them to be and monitor them a little more frequently just in case I'm wrong about the air flask or the PNOK theories.
    Good Luck!
    (You may need it! :eek: )
    EDIT:
    LOL!!!!
    You HAVE to love the SPAM generator in this forum!!! :)
    I have a new theory!!!!!!
    Somebody is trying to generate revenue for one of these:
    Nitrogen System For Tires
    Generation Systems From $1,995.00 Nitrogen Generators For All Uses
    #18 ETC(SS), Feb 26, 2015
  19. Mendel Leisk
    38,652
    There's maybe a clue there. Can you clarify?
  20. bisco
    49,393
    costco inflated the tyres with nitrogen at -10 degrees and at 30 degrees nitro will increase to 55.
