who has changed out speakers on a JBL equipped Prius?
Discussion in 'Gen 2 Prius Audio and Electronics' started by LIPriusFreak, Jun 20, 2011.
  1. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    my 06 has the JBL with nav upgraded system. I want to keep nav as is but my speakers crackle. I know the speakers are riveted in and carry a 2.5 ohm load and wired to the jbl amp under passenger front seat...
    i've searched and searched and can't get a handle on this...can I upgrade the speakers while retaining the factory HU?
    if so, am i limited to 2 ohm speakers?
  2. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    might want to check out the crutchfield website and use their fitement guide
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    4 ohm speakers won't damage anything. but everything else being equal, you will lose some volume. Look for speakers with a high sensitivity rating and that will minimize volume loss.
    Speakers Glossary
  4. LIPriusFreak
    449
    34
    Long Island, NY
    will I retain the stock amp or will it be bypassed? Do I need a new amp?
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    As long as you can get the volume you want out of the 4 ohm speakers with your old amp, it will be OK. If you aren't using a lot of volume now you will probably be OK but you won't know until you try it, in any case it won't hurt your amp.
  6. LIPriusFreak
    449
    34
    Long Island, NY
    awesome i will try it
  7. linus
    linus Junior Member
    WA
    2018 Prius
    Three Touring
    I swapped mine out about a month ago with some Infinity Kappa speakers. I did lose a little volume, but they sound much better. For reference, the tunes I played at about "15" volume with the JBL speakers now play at about 20-25 with the Infinitys. I've never had any reason to max it out.
    I did disconnect the front door tweets (too much hassle to replace, so they just sit there), and replaced the rear door ones. I'm still looking for a good replacement for the center dash speaker.
    The biggest problem I found was the shallow depth of the face of the new speakers. There was a gap between the new speakers and door panel, so the inside of the door filled with sound. I made a tunnel out of foam tape that now sends the sound straight out. Sounds great.
    Nav, Bluetooth, etc. all still work fine.
  8. LIPriusFreak
    449
    34
    Long Island, NY
    interesting...many thanks for the input...did you go with Kappas because of the 2ohm impedence (JBLs are 2.5) or you just like them?
    do the stock tweeters and center channel still work?
  9. linus
    linus Junior Member
    WA
    2018 Prius
    Three Touring
    The stock tweeters and center channel still work. The front tweets will stay unplugged, and I'll get the center going again when I find a good replacement. With the center going again, I think volume will match stock again.
    I was just lazy and went with the most common set I found after some quick research:
    http://members.cox.net/scott.sumners/Prius Speaker Replacement by ~sparky~.pdf
    and they were a good deal through CarToys at the time.
    The 62.9i set I put in the front has nice dome tweets in the center. I never like the sound of the ones up in the corner of the door anyway, so I just unplugged them. I can plug them back in, and that adds some volume, but they don't sound nearly as good as the others.
    The 60.9cs set worked well in the back. The 6.5's give good bass back there. I just enlarged the hole in the upper door for the tweeters and used the Infinity mounting bracket. I think those tweeters are my favorite part of the setup.
