Who has had a incomplete charge
Discussion in 'Prius PHEV Plug-In Modifications' started by boxer93, Sep 8, 2008.
  1. boxer93
    boxer93 Psyched for PHEV
    155
    22
    Southern NH
    I read in one post that made it sound like everyone was having the problem. I'll be talking to Erin about my specific situation so she can convey it to her techs. How about you?
    Chris
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    What does this post mean? I'm confused.
    Tom
  3. boxer93
    155
    22
    Southern NH
    Re: Who has had a incomplete pack charge
    Sorry qbee,
    For Hymotion PHEV owners. When you plugged in your car at night. In the morning is the pack not completely full of electricity (charged). This has happened to me twice and I decided to start a new thread vs keeping the other one off topic. I talked with Erin this morning to give her my information to pass on to their technical staff.
    Chris
  4. Zythryn
    Zythryn Senior Member
    6,260
    4,260
    I have not had a partial charge so far (11 days so far).
    Car is in a garage although it has been charged outside three times.
    Temperatures in the 60s and 70s for most of that time, 80s the first few days.
  5. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    You know from the other thread that I've had two, and I'm interested in hearing Hymotion's reply.
  6. chogan2
    1,066
    756
    Virginia
    got a call back from A123. I'll post what I know here and in the other thread that mentions incomplete charges.
    They purchase the charger component.
    They have had some customers with incomplete charges that appear to be due to using an extension cord with too small a gauge or too long a run.
    The issue of heat as a factor has not come up before.
    The system is designed so that heat should not be a factor.
    In my case, I already noticed a 10V drop at the wall socket when I charge (which is more than I ought to get, in theory, based on 14 gauge house wiring.) And I'm using a 25' 14 gauge cord on top of that.
    My guess, as of this moment, is that heat = AC use = momentary voltage drops, and that my partial charge issue is the same as the partial charge issue for people who used narrow-gauge or long extension cords. (Too small or too long a cord gives too much voltage drop.)
    Bottom line: at this point, I think it's a low voltage issue for me. The voltage drop at the wall socket is already worrisome. My electrical service is probably right at the margin of providing continuous adequate voltage. I'm going to get/make a shorter 10-gauge cord, and I'm considering running a dedicated 12 or 10 gauge line directly back to the electrical service entrance, and give the car its own dedicated circuit. But if a 10 gauge cord does the trick, I'm not going to bother with that.
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I see about a 6-8 volt drop during my charging. Normal voltage is around 122V and drops to the 114V area when charging.
    I don't know what gauge my 25ft cord is but I know its a big thick heavy one. Its not one of the household extension cords. I'll have to check it when I get home. I think the Watts Up? meter uses the same gauge as my cable or maybe one size smaller. You can see the size of it in my video I posted in my Hymotion review topic.
    I do know out of all the charges I have gone through so far the only thing that changed on my "partial charges" was the heat.
  8. boxer93
    155
    22
    Southern NH
    Thanks for the replys. I also talked with Jim today and he echoed the 'light duty' extension cords. He also did state 14gauge for 25' and 12gauge for longer. chogan2, 10gauge would probably be overkill, plus I don't know how easy it would be to find stranded copper at that size. That gauge is usually for 30-50amp circuits that would draw upwards of 5000kWh. If your house circuit is 14gauge for a long run that may be a larger contributor to the voltage drop. If rerunning the house circuit as 12gauge is expensive you could always check to see if you could buy something like a line conditioner or UPS that would 'buffer' the voltage at the end of the circuit. I have no experience with this, just something I had thought of if my voltage was too low.
    One other thing that Jim stated was if the LED on the hymotion switch was flashing, that would indicate a problem and 123 should be contacted.
    Chris
    PS. I have found that most extention cords have the wire rating embossed in the plastic/rubber coating. Can be a pain to see, but you will know the gauge of the wire if you don't have the original packaging.
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    My 25ft extension cord is 12 gauge and the Watts Up? meter is 14 gauge. The wire running from the circuit breaker is 14 gauge and is about a 100ft run to the garage.
    It was pretty hot today but not as hot as when it was when I got a partial charge. I have tomorrow off but I have to take my car the dealership to see about getting my headlights fixed. So I don't know if I will get to see a partial charge or not and if I do I will hold out for as long as I can to see if it starts to recharge on its own.
  10. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    You should be able to find it at Home Depot. I bought some 4 conductor 8 gauge stranded their a while back, they called it appliance cord I think. Was building a temporary extension cord to run my range off my dryer outlet (don't ask) :rolleyes:
    If you are concerned about your in-wall losses, I would definitely try to oversize your extension cord. 10 would probably be sufficient for that. The line conditioner idea is a pretty good one, here's an example:
    LCR2400 - Line Conditioner - Automatic voltage regulation with surge protection
    Provides up to 20A at 120V for inputs as low as 87V. Street price looks to be about $300.
    If you have access to the wires anywhere along your in wall run (attic maybe?) I'd just be sure they aren't heating up causing a possible fire hazard. You're probably ok, but those voltage drops are a little surprising. Probably worth checking out though before you chose to go any route other than upgrading your in wall wiring.
    FWIW, I know nothing about Hymotion's system, but its not at all unreasonable to think that high temperatures could exacerbate a marginal input voltage situation.
    Rob
  11. chogan2
    1,066
    756
    Virginia
    Yeah, at this point, with the car charging OK, the house wiring is my main concern. The voltage drop is about twice what I ought to get, based on that length of 14 gauge wire. If that's just the cumulative effect of a bunch of 50-year-old splices in the circuit, no problem. If it's one bad connection in that circuit, it's like sticking a 50 watt incandescent inside a metal junction box somewhere in my house walls, and letting that run a few hours every night (extra 5v drop x 10A current = 50W). That's a little worrisome.
    I'm trying to figure out what to do, if anything. The easy answer is "hire an electrician", but I want to understand what's going on. If I have a problem in this circuit, I may have it in others. I think I'll test the voltage drop all along the circuit (with a space heater and the kill-a-watt), see if it jumps at any point.
    A line conditioner is a reasonable option, except that I'm worried about the house wiring. To cover the losses within the conditioner itself, plus charge the car, I'd end up drawing even more amps through the house wiring. So I'm not going there until I figure out if I have a problem with the wiring.
    On the 10 gauge cord, I finally thought to run that through a voltage drop calculator. It only knocks 0.4V off the total voltage drop, compared to 12 gauge. Now that doesn't seem worth it, I'll just use off-the-shelf 12 ga cord.
    Voltage Drop Calculator
    On the other hand, A123's minimum extension cord recommendation (50' 12ga or 25' 14ga) amounts to avoiding an additional 1.1V drop in the cord (ie, between 50' 14ga and 50' 12ga) So maybe it is that sensitive.
  12. boxer93
    155
    22
    Southern NH
    If your housewiring is old enough with many splices I would worry about a bad splice heating up the wiring too. Easy enough for me to say since any wiring added or replaced I've done myself. It's good to see you progessing cautiously. I agree with the sensitivity. Heat, kill-a-watt, it may be an accumulation of effects. When I used my kill-a-watt I don't have good access to read it from the outlet (mounted on the ceiling) so I had extensioncord(16awg) to kill-a-watt to extension cord (16awg short pigtail) to bumper. I plan not to do that again :dumb:
    Chris
  13. chogan2
    1,066
    756
    Virginia
    Another hot day, and another partial charge. Yesterday, by the end of the day, the car was hot enough that it would not go into EV mode. And, the Hymotion battery would not fully charge.
    I Had to unplug and replug twice to get the battery to charge fully.
    Maybe its a combination of heat plus low line voltage, but it certainly seems like heat is the trigger.
    At this point, I am not a happy customer. Yes, the mileage is good -- right now we're at just over 90 mpg and rising, having gone less than 200 miles with the Hymotion battery installed. But for $11K, it ought to work properly under reasonable real-world conditions. My house is wired according to code and I'm using a big enough extension cord. But I live in Virginia, and that car is going to be hot quite a bit of the time.
    At this point, until I settle this, I've decided to keep the car outside when recharging it. If it's getting too hot to charge properly, I don't want to charge it inside the garage.
  14. SVPriusFan
    SVPriusFan Hymotioned and loving it...
    115
    Denver Suburbs
    Hey, just an FYI - I just spoke with Erin at A123 this morning about my install date and happened to mention the issue raised by this thread. She told me that there were some problem components associated with some of the very first L5 packs that contributed to the partial-charge problem. She has already replaced one and said that all systems going to install centers from this time forward shouldn't have any problems. She also said that the unit is covered by warranty so if anyone else is experiencing this problem they'll fix/replace it.
    She also explained they don't supply an extension cord but any off-the-shelf 25' orange 14-gage you can find at Home Depot or similar will work just fine. There shouldn't be any charging problems due to temperature from what she said.
  15. boxer93
    155
    22
    Southern NH
    Interesting news. Also on the cord if you can swing a 25' 12AWG it may be worth a small piece of mind. I have not had any partial charges since I changed and have not tried the kill-a-watt again, yet.(Also I actually bought a 25' cord and cut in half and made 2 cords. One for my garage and one for the car)
    Chris
  16. adagiopop
    adagiopop Junior Member
    Ohio
    We got our L5 on 9/19 and have not had any incomplete charges. We did get a new 25 ft, 14 gauge extension cord for recharging. The car is parked inside and we have had moderate weather lately. We live in the Cleveland area and it will be interesting to see what happens when the weather changes.
